There isn't much to a radio except capacitors, resistors, and coils (and tubes). If you get to a dead point, check coils for continuity, capacitors for shorts (and opens), and resistors for opens (and drifting). If all checks out well, check to see that you can tune coils to frequency. If you can't, there may be a partial short within the coil. If this is the case, it would help to have a chart of DC resistances for the coils.
...And finally check ALL wiring, and check individual tube element continuity (can be done with most tube testers).
Good advice. When the oscillator is working, and the set has audio output and gain, and someone tells about the radio being taken to a shop and found to be non-repairable, the most common problem I have found is one of the IF transformers. Either an open winding (wire was stripped with acid before soldering, and not cleaned well - over time the remaining acid eats the wire in two), or leaching of silver in one of the internal capacitors. Other folks may have had other experience.
Let me ask. I know this radio has been messed with. Is there any basic setting for all trimmers and padders to be set? In other words... screw it all the way down and then back out 1/4, 1/2 turn and so on?
This procedure will usually solve just about every "doesn't work" problem that arises on this forum.
I always start at the power supply wwith a Voltmeter and check Voltages. Then I check the audio amplifiers with an audio generator or a transistor (battery operated) with a minature phone jack plugged into the output, and connected across the volume control. These are the simpler circuits to troubleshoot. Once you have those working to your satisfaction, you are ready to tackle the RF, Osc-mixer, and the IF, 455 kHz or whatever, and backward to the oscillator-mixer, which you say you can find on a good radio. Great, that is about the hardest part of the radio to understand and repair. But first, check the audio. A finger to the center tap of the vollume control will give us all a wealth of information.
![]() Some evaluation of the tone control circuitry can even be made at the higher frequencies by the “colorization” of the tone control, upon the produced signal. Next question. . ..after the mod RF sig generator availability will be if you have . . . ..preferably, one of the OLD generation fluorescent desk lamps with 1-2 small tubes and the “all important” OLD generation common metal ballast transformer. (Also, some aquariums top illumination lamps, are of that category as well as “gro lux” plant lamps, kids older style black light lamps, etc.) The new generation CFL lamps with their “electronic ballasts” are LESS than desirable with their sharp banding of switch mode activity within 60-75-120 khz clusters. Standing by. . . ..
