Hoo, boy!! That tapped primary. The 35L6 is a 2000 Ohm tube, so a 2k to voice coil will work if you just connect the B+ to the 1.2k resistor, should be jes' fine. If you want to be strictly original, I don't know where you would find an exact replacement transformer.
If you cannot replace the transformer with a duplicate, and you find the hum objectionable, let me know if you want the negative feedback circuit. It is simple, and works well. There is another version that others have suggested on here that is to simply tie the low end of the volume control to the chassis through the output transformer secondary (connect transformer so as to provide negative and not positive feedback). However, I found that even with negative feedback there still is some objectionable high frequency oscillation. Try it out and if you don't like it, I can give you my circuit: a couple of resistors and capacitors.
![]() I wonder what is your analysis of failure mode on that unit, an open primary winding ? If the primary is open, have you vewwy carefully, surgically peeled back the thin fishpaper covering and used a magnifier, hi-intensity light, surgical tweezers and ohmmeter to see if you lucked out, with the break being externally-accessible and can be micro-repaired on the re connection to its main lead wires. 1012-072 OUTPUT THOROTEST TA20T SP (1.7K z0 TO 3.2 VC, W/HUM TAP, 3-5 WATTS, FIG 3, NEW.. 1 2 3/8 1 3/8 1 1/2 $7.50 |
