Need Schematic and Model #
3/29/2009 9:05:48 PMJohn Chidester
This is a floor model about 2-1/2 foot high Airline (no Model#on plate)chassis #31, 115V, 85W, 60cys, Screen Grid, Hazeltine and Latour patients, Montgomery Ward. 3 controls--on/off/volume, base/trebel, and tuning situated in triangle pattern. Drum dial(3/4 inch wide) with light inside. Tubes 2-45s, 3-24s, 2-227s and 1-232. Power supply has 3 copper canned eletrolitics bound together(with metal shield) and mounted in an upright position thru chassis. Another square metal shield covers this.
3/29/2009 9:14:14 PMNorm Leal
Hi John
It's an old one. Probably made in 1929 or 1930. The 232 may be a wrong number? That tube was made for a battery radio.
Schematics can be found here:
http://www.nostalgiaair.org/Resources/265/T0000265.htm
See if you can find similar numbers on your radio?
:This is a floor model about 2-1/2 foot high Airline (no Model#on plate)chassis #31, 115V, 85W, 60cys, Screen Grid, Hazeltine and Latour patients, Montgomery Ward. 3 controls--on/off/volume, base/trebel, and tuning situated in triangle pattern. Drum dial(3/4 inch wide) with light inside. Tubes 2-45s, 3-24s, 2-227s and 1-232. Power supply has 3 copper canned eletrolitics bound together(with metal shield) and mounted in an upright position thru chassis. Another square metal shield covers this.
3/31/2009 8:33:01 PMJohn Chidester
Thanks Norm. I had already gone thru all these. The 232 is correct unless they changed the socket also, socket and tube match. :Hi John
: It's an old one. Probably made in 1929 or 1930. The 232 may be a wrong number? That tube was made for a battery radio.
: Schematics can be found here:
: http://www.nostalgiaair.org/Resources/265/T0000265.htm
: See if you can find similar numbers on your radio?
::This is a floor model about 2-1/2 foot high Airline (no Model#on plate)chassis #31, 115V, 85W, 60cys, Screen Grid, Hazeltine and Latour patients, Montgomery Ward. 3 controls--on/off/volume, base/trebel, and tuning situated in triangle pattern. Drum dial(3/4 inch wide) with light inside. Tubes 2-45s, 3-24s, 2-227s and 1-232. Power supply has 3 copper canned eletrolitics bound together(with metal shield) and mounted in an upright position thru chassis. Another square metal shield covers this.
