Well, I don't know the manufacturer of your radio, but imaging is a phenominum that occurs at exactly twice the IF of the radio. If you work at an airport, for the FM band the image will be 2 X 10.7, or 21.4 mHz above the FM band. The aircraft navigation band starts at 108.0 mHz, and switches to communication at 118.0 mHz thence to 135 mHz. So the upper limit of FM is 108.0, the image would be at 129.4. Believe me, I worked at a very busy airport for 35 years, and listening ot FM was about of the question on the stations that had images in the aircraft band. I think Atlanta has a radio on every frequencv known to man. So, if you are getting IF stations at several places on the band, I would suspect the IF is passing several frequencies.
![]() Relevant to the "image"": I might suspicion an extra " mixer" problem in the RF front end, in the respect of a poor connection / galvanic corrosion acting as a "semiconductor" and throwing some spurious signals in CONSIDERING there is a strong local signal nearby to you that could be providing the strong RF for that additional mixing action
