resistors
3/28/2009 8:57:02 AMalan
Hello from Auatralia,I am using a schematic which shows a few resistors having a value of 0.1 ,I have never seen this before,.1 of what.
Thanking you in anticipation
Regards Alan
3/28/2009 9:13:30 AMthat seems low
:Hello from Auatralia,I am using a schematic which shows a few resistors having a value of 0.1 ,I have never seen this before,.1 of what.
:Thanking you in anticipation
:Regards Alan
are you sure they are resistors? for some solid state stuff i seen some low value ones but are essentially jumpers. that sounds like it might be a capacitor value? what is the schematic?
3/28/2009 9:24:59 AMAlan
They are resistors as they show typical resistor lines and are then followed by a cap, must be a misprint. Thankyou
3/28/2009 9:54:40 AMNorm Leal
Hi Alan
I've seen resistors like this in transistor circuits. Are they in emitter circuits of output transistors? Wire wound resistors of .1 ohm exist.
:They are resistors as they show typical resistor lines and are then followed by a cap, must be a misprint. Thankyou
