Motorola tube & transistor hybrid radio.
3/28/2009 8:20:35 AMAtsushi Takagi(72503:0)
Does some one know the Motorola tube & transistor hybrid radio? I have green one with oval speaker design. I want to know the model number and sckematic diagram.
3/29/2009 10:50:08 PM[:o)<===(72571:72503)
:Does some one know the Motorola tube & transistor hybrid radio? I have green one with oval speaker design. I want to know the model number and sckematic diagram.
3/30/2009 1:43:29 PMEdd(72591:72571)
There was a VERY short time era where there was the use of the “space charge” tubes feeding into a Germanium Power Output transistor. Circa ~1958. What we would need is for you to examine the set and locate a model number to be able to research from.
Motorola is usually good, in the respect of their model numbers being pressed / stamped deeply into the metal of the housing of the radio. Thus, you still being able to get that model number; otherwise, I don’t think any research could be done without its model number to work from.
