Philco model 20
3/21/2009 9:30:10 PMJohn
Can't get any stations but one or two on the high end and then they aren't any too loud. Have changed filters and checked resistors and changed several that were off but remains the same.
3/21/2009 11:53:17 PMLou
Is this a TRF set or a regen?
If it is a regen, then the local oscillator being generated may not be there . Check the frequency of the stations you receive and see if they correlate with the capacitor settings.
If it is a TRF, check for weak tubes or tube voltages.
I can't seem to pull up the schematic easily at home tonite or I could tell.
Lou
:Can't get any stations but one or two on the high end and then they aren't any too loud. Have changed filters and checked resistors and changed several that were off but remains the same.
3/22/2009 7:34:08 AMJohn
:Is this a TRF set or a regen?
:If it is a regen, then the local oscillator being generated may not be there . Check the frequency of the stations you receive and see if they correlate with the capacitor settings.
:If it is a TRF, check for weak tubes or tube voltages.
Hi Lou,
Thanks for your reply. It is a TRF set. I have checked tubes and they all seem to check good and tube voltages are there.
:I can't seem to pull up the schematic easily at home tonite or I could tell.
:Thanks
:Lou
::Can't get any stations but one or two on the high end and then they aren't any too loud. Have changed filters and checked resistors and changed several that were off but remains the same.
3/23/2009 12:56:46 AMLou
:OK
Are all the capacitors (variable) tracking each other?
If the caps are mis-aligned relative to each other the tuning will be weak or non-existent.
To tell, you have to tune to a station, loosen one cap on its shaft, and move it around to see if the gain gets better.
Ciao
Lucio
::If it is a regen, then the local oscillator being generated may not be there . Check the frequency of the stations you receive and see if they correlate with the capacitor settings.
::If it is a TRF, check for weak tubes or tube voltages.
:Hi Lou,
:Thanks for your reply. It is a TRF set. I have checked tubes and they all seem to check good and tube voltages are there.
::I can't seem to pull up the schematic easily at home tonite or I could tell.
::Thanks
::Lou
:::Can't get any stations but one or two on the high end and then they aren't any too loud. Have changed filters and checked resistors and changed several that were off but remains the same.
3/23/2009 6:11:24 AMJohn
::OK
:Are all the capacitors (variable) tracking each other?
:If the caps are mis-aligned relative to each other the tuning will be weak or non-existent.
:To tell, you have to tune to a station, loosen one cap on its shaft, and move it around to see if the gain gets better.
:Ciao
:Lucio
::Is this a TRF set or a regen?
:::If it is a regen, then the local oscillator being generated may not be there . Check the frequency of the stations you receive and see if they correlate with the capacitor settings.
:::If it is a TRF, check for weak tubes or tube voltages.
::Hi Lou,
::Thanks for your reply. It is a TRF set. I have checked tubes and they all seem to check good and tube voltages are there.
:::I can't seem to pull up the schematic easily at home tonite or I could tell.
:::Thanks
:::Lou
::::Can't get any stations but one or two on the high end and then they aren't any too loud. Have changed filters and checked resistors and changed several that were off but remains the same.
Hi Lou,
Well after rebuilding the capacitor blocks I get stations across the dial but they are all somewhat weak in volume. The diagram shows 50 volts on the grids of the 71a's and I only have -8 there so think that's why the weak volume. Don't see where they are getting the 50 volts.
3/23/2009 1:38:31 PMphil
hi,iirc grid voltage is measured from filament to grid,not chassis to grid.
which way are you measuring it?
:::OK
::Are all the capacitors (variable) tracking each other?
::If the caps are mis-aligned relative to each other the tuning will be weak or non-existent.
::To tell, you have to tune to a station, loosen one cap on its shaft, and move it around to see if the gain gets better.
::Ciao
::Lucio
:::Is this a TRF set or a regen?
::::If it is a regen, then the local oscillator being generated may not be there . Check the frequency of the stations you receive and see if they correlate with the capacitor settings.
::::If it is a TRF, check for weak tubes or tube voltages.
:::Hi Lou,
:::Thanks for your reply. It is a TRF set. I have checked tubes and they all seem to check good and tube voltages are there.
::::I can't seem to pull up the schematic easily at home tonite or I could tell.
::::Thanks
::::Lou
:::::Can't get any stations but one or two on the high end and then they aren't any too loud. Have changed filters and checked resistors and changed several that were off but remains the same.
:Hi Lou,
:Well after rebuilding the capacitor blocks I get stations across the dial but they are all somewhat weak in volume. The diagram shows 50 volts on the grids of the 71a's and I only have -8 there so think that's why the weak volume. Don't see where they are getting the 50 volts.
3/23/2009 7:28:50 PMJohn
My fault, was going from grid to ground. Have 50 from pin 1 to 3. Still can't figure why volume is so low.
:hi,iirc grid voltage is measured from filament to grid,not chassis to grid.
:which way are you measuring it?
::::OK
:::Are all the capacitors (variable) tracking each other?
:::If the caps are mis-aligned relative to each other the tuning will be weak or non-existent.
:::To tell, you have to tune to a station, loosen one cap on its shaft, and move it around to see if the gain gets better.
:::Ciao
:::Lucio
::::Is this a TRF set or a regen?
:::::If it is a regen, then the local oscillator being generated may not be there . Check the frequency of the stations you receive and see if they correlate with the capacitor settings.
:::::If it is a TRF, check for weak tubes or tube voltages.
::::Hi Lou,
::::Thanks for your reply. It is a TRF set. I have checked tubes and they all seem to check good and tube voltages are there.
:::::I can't seem to pull up the schematic easily at home tonite or I could tell.
:::::Thanks
:::::Lou
::::::Can't get any stations but one or two on the high end and then they aren't any too loud. Have changed filters and checked resistors and changed several that were off but remains the same.
::Hi Lou,
::Well after rebuilding the capacitor blocks I get stations across the dial but they are all somewhat weak in volume. The diagram shows 50 volts on the grids of the 71a's and I only have -8 there so think that's why the weak volume. Don't see where they are getting the 50 volts.
3/24/2009 11:18:52 AMphil
do you have plate voltage on both 71a's?
may have 1 winding open on output trans.
with radio playing pull each 71a one at a time,there should be a volume change on each tube,no change-there's your problem.
i assume both tubes are good?
:My fault, was going from grid to ground. Have 50 from pin 1 to 3. Still can't figure why volume is so low.
::hi,iirc grid voltage is measured from filament to grid,not chassis to grid.
::which way are you measuring it?
:::::OK
::::Are all the capacitors (variable) tracking each other?
::::If the caps are mis-aligned relative to each other the tuning will be weak or non-existent.
::::To tell, you have to tune to a station, loosen one cap on its shaft, and move it around to see if the gain gets better.
::::Ciao
::::Lucio
:::::Is this a TRF set or a regen?
::::::If it is a regen, then the local oscillator being generated may not be there . Check the frequency of the stations you receive and see if they correlate with the capacitor settings.
::::::If it is a TRF, check for weak tubes or tube voltages.
:::::Hi Lou,
:::::Thanks for your reply. It is a TRF set. I have checked tubes and they all seem to check good and tube voltages are there.
::::::I can't seem to pull up the schematic easily at home tonite or I could tell.
::::::Thanks
::::::Lou
:::::::Can't get any stations but one or two on the high end and then they aren't any too loud. Have changed filters and checked resistors and changed several that were off but remains the same.
:::Hi Lou,
:::Well after rebuilding the capacitor blocks I get stations across the dial but they are all somewhat weak in volume. The diagram shows 50 volts on the grids of the 71a's and I only have -8 there so think that's why the weak volume. Don't see where they are getting the 50 volts.
3/25/2009 7:35:39 AMMystery solved
Radio runs now with all kinds of volume. I noticed over 200 volts on the plate of the first 24 but only 100 on the plate of the second 24 and so wondered why so big a difference. Got to ohm metering around and the rf transformer winding feeding this plate measured open. Took it out and still seemed open although no visual break or problem. I put some double back scotch tape over the old winding and wound about the same # of turns onto the tape, reinstalled and have all kinds of volume. I don't know how the radio could have run at all with that coil open. It had low volume across the band. Worked fine but just weak volume.
:do you have plate voltage on both 71a's?
:may have 1 winding open on output trans.
:with radio playing pull each 71a one at a time,there should be a volume change on each tube,no change-there's your problem.
:i assume both tubes are good?
::My fault, was going from grid to ground. Have 50 from pin 1 to 3. Still can't figure why volume is so low.
:::hi,iirc grid voltage is measured from filament to grid,not chassis to grid.
:::which way are you measuring it?
::::::OK
:::::Are all the capacitors (variable) tracking each other?
:::::If the caps are mis-aligned relative to each other the tuning will be weak or non-existent.
:::::To tell, you have to tune to a station, loosen one cap on its shaft, and move it around to see if the gain gets better.
:::::Ciao
:::::Lucio
::::::Is this a TRF set or a regen?
:::::::If it is a regen, then the local oscillator being generated may not be there . Check the frequency of the stations you receive and see if they correlate with the capacitor settings.
:::::::If it is a TRF, check for weak tubes or tube voltages.
::::::Hi Lou,
::::::Thanks for your reply. It is a TRF set. I have checked tubes and they all seem to check good and tube voltages are there.
:::::::I can't seem to pull up the schematic easily at home tonite or I could tell.
:::::::Thanks
:::::::Lou
::::::::Can't get any stations but one or two on the high end and then they aren't any too loud. Have changed filters and checked resistors and changed several that were off but remains the same.
::::Hi Lou,
::::Well after rebuilding the capacitor blocks I get stations across the dial but they are all somewhat weak in volume. The diagram shows 50 volts on the grids of the 71a's and I only have -8 there so think that's why the weak volume. Don't see where they are getting the 50 volts.
3/25/2009 11:32:29 AMChuc Schwark
Capacitive coupling between windings in the IFT.
CS
3/25/2009 7:36:21 PMEdd
Hmmmm, I also had a reply for you but it was ALSO audio oriented, just took too long to for me to find my archived schema markup
of a Peeelco 20 chassis.
I had made it up and was helping a person last year, in clarifying the manner of operation of that sets tandem ganged
volume (RF gain ) control as is used in that chassis design.
I would assume that the old generation wire, solder flux residue and humidity transferred airborne oxidants finally got
to that RF coil, with the corrosive onset of the “Blue-Green Glooomphs” (aka . . .CuSO4).
Also, initially, you must have had some of that above chemical path /resistive residue on the winding in order to be
reading the, appreciably low, measured 2nd R.F.’s plate voltage.
Without RF from that tubes plate to its RF plate coil primary, there wouldn’t even be any RF to be capacitively coupling
across that transformers primary to secondary.
I’m including that aforementioned #20 clarified mark-up at the bottom, in case any further circuit tracing is needed:
Peeelco Model 20 . . . . . Clarified Schematic :
