What is not clear to me is how to actually do this. Does anyone have any experience or advice to share?
Lode Swinnen
lswinnen@aol.com
Use a power supply and monentarily connent the open winding across this voltage. 100 volts will usually work. This has an arc welding effect and sometimes makes a connection.
I have even found cases where the high ohm's scale on a meter causes a connection. Many meters use a 22 1/2 or 30 volt battery on this scale while lower scales have 1 1/2 volts.
Repairing coils this way doesn't always hold up over time but it's worth a try.
: I have seen the use of a high voltage or an electric discharge recommended by more than one source, as a way to re-establish continuity for open interstage transformer windings or for horn speakers. The theory is that a crystallized solder/copper interface is responsible for the open circuit.
: What is not clear to me is how to actually do this. Does anyone have any experience or advice to share?
: Thanks
: Lode Swinnen
: lswinnen@aol.com
Thank you for the advice. I'll give it a try.
Lode
: Lode
: Use a power supply and monentarily connent the open winding across this voltage. 100 volts will usually work. This has an arc welding effect and sometimes makes a connection.
: I have even found cases where the high ohm's scale on a meter causes a connection. Many meters use a 22 1/2 or 30 volt battery on this scale while lower scales have 1 1/2 volts.
: Repairing coils this way doesn't always hold up over time but it's worth a try.
: Norm
: : I have seen the use of a high voltage or an electric discharge recommended by more than one source, as a way to re-establish continuity for open interstage transformer windings or for horn speakers. The theory is that a crystallized solder/copper interface is responsible for the open circuit.
: : What is not clear to me is how to actually do this. Does anyone have any experience or advice to share?
: : Thanks
: : Lode Swinnen
: : lswinnen@aol.com
