Best to verify all the wiring in relation to a schematic. Use a highlighter or colored pencil to show what you've checked.
Could be a short in the B+ ckt.
Doug
Also, double check that the caps' polarity is correct.
Doug
:HI FOLKS I STARTED TO RECAP THIS CROSLEY AND WAS DOING OK I WOULD CHECK AFTER REPLACING A CAP EVERY THING WAS GOING OK UNTILL I GOT CARRIED AWAY SINCE EVERYTHING HAD WORKED OK SO I DID SEVERAL BEFORE CHECKING AND WHEN I FINISHED I PLUGED BREFILY AND THE RECTIFIER TUBE FLASHED I QUICKLEY PULLED THE PLUG.
:DOES ANY HAVE ANY IDEA WWHERE I MAY HAVE WENT WRONG.
