Check schematic here on nostalgiaair under Rider. Model 35, metal, will be on the same page as 30 which was wood.
You will need a filament supply. Tubes require 5 volts. Use a little higher as there is a rheostat to reduce the voltage on your radio. B+ voltage should be 67 1/2 to 90 volts. Detector requires 22 1/2 volts. This radio also should have a C voltage of -4 1/2 volts.
You will find this information along with the color of wires on the schematic..
: I have recently come across a model 35 reciever and speaker. I have no clue as to what the battery cable connection/voltages should be. Could anyone supply me with the voltages, and possibly a schematic of a battery elliminator
If no C battery is used, connect the two C battery leads together.
I have encountered references that indicate it as a "2 volt" set. Nothing consistent to prove A.K. intended it that way, in fact my 35 has the tag that indicates 01A series tubes. Type 30's will work fine, just use a lower filament voltage of 2 volts.
: Hi Tyler
: Check schematic here on nostalgiaair under Rider. Model 35, metal, will be on the same page as 30 which was wood.
: You will need a filament supply. Tubes require 5 volts. Use a little higher as there is a rheostat to reduce the voltage on your radio. B+ voltage should be 67 1/2 to 90 volts. Detector requires 22 1/2 volts. This radio also should have a C voltage of -4 1/2 volts.
: You will find this information along with the color of wires on the schematic..
: Norm
: : I have recently come across a model 35 reciever and speaker. I have no clue as to what the battery cable connection/voltages should be. Could anyone supply me with the voltages, and possibly a schematic of a battery elliminator
