I've experimented with various methods of rejuvenating oxide coated cathodes with minimal success. Usually the result was temporary and undependable. However, upon reading that some fault was caused by gas and ion bombardment, and that the getter in really old tubes doesn't really do much unless it's heated, I decided to try something new. I just bought some nice G-45s for my Majestic, and they're great, but they are weak, which is why I could afford them. I'm not interested in experimenting with them at this point. However, I decided to experiment with an ST 45 I have that is less valuable, and tests in the REPLACE region on my tester. It still works fairly well, but definitely is weak. I put the tube in the oven (vertical with nothing touching the glass) and turned the control up to 500 degrees. Unfortunately the bakelite base started popping at about 450 degrees, so I had to turn the oven back off (I expected that this might happen). However, I let the tube cool with the oven, and then, after all was cool, I tested the tube. It tested in the GOOD range! It tested in the same exact place over and over again, even after putting it in the radio and running it for a bit. WOW! Too bad it isn't easier to remove bases from tubes, or else I'd bake more tubes. Baking the bakelite base not only ruins its appearance and makes a big smell, but it also spreads the pin spacing due to swelling, so the pins don't line up properly anymore. Also, as would be expected, the solder connections need to be remade. However, if a method can be devised of easily removing the base without destroying the tube, a lot of valuable/rare tubes might be able to be rejuvenated using this method.
:Well, at the risk of being bombarded with criticism and vulgarities that are so common as of late, I just had to post this because it's amazing!
:I've experimented with various methods of rejuvenating oxide coated cathodes with minimal success. Usually the result was temporary and undependable. However, upon reading that some fault was caused by gas and ion bombardment, and that the getter in really old tubes doesn't really do much unless it's heated, I decided to try something new. I just bought some nice G-45s for my Majestic, and they're great, but they are weak, which is why I could afford them. I'm not interested in experimenting with them at this point. However, I decided to experiment with an ST 45 I have that is less valuable, and tests in the REPLACE region on my tester. It still works fairly well, but definitely is weak. I put the tube in the oven (vertical with nothing touching the glass) and turned the control up to 500 degrees. Unfortunately the bakelite base started popping at about 450 degrees, so I had to turn the oven back off (I expected that this might happen). However, I let the tube cool with the oven, and then, after all was cool, I tested the tube. It tested in the GOOD range! It tested in the same exact place over and over again, even after putting it in the radio and running it for a bit. WOW! Too bad it isn't easier to remove bases from tubes, or else I'd bake more tubes. Baking the bakelite base not only ruins its appearance and makes a big smell, but it also spreads the pin spacing due to swelling, so the pins don't line up properly anymore. Also, as would be expected, the solder connections need to be remade. However, if a method can be devised of easily removing the base without destroying the tube, a lot of valuable/rare tubes might be able to be rejuvenated using this method.
:T.
WOW! If I could make my Majestic G-45 tubes test like new again, that would be terriffic! I will stick to less valuable tubes for now.
Don't use acetone. That WILL melt the base. Lacquer thinner is what you need to get.
I will consider the heat gun method. I like thoroughly baking the tube better, since it is thorough on all sides of the glass, but I may try the heat gun (if I can find my dad's). I do know that you can move the heat gun around, but I don't know how the glass will like that as opposed to an oven.
When the tube is in the oven, its glass must not touch anything, so if the base is removed, it would be best to hang it somehow by its wires (perhaps a vice grips).
Today I'm going to try some all glass 12AU7s that are "Replace," and one that's definitely gassy. Then, if I have success with the bases, I have an 80 that is weak and gassy and a 47 that is Replace, but not gassy as far as I know. The 47, when it was used in a Century radio that I do not own, functioned very poorly (barely). The 45 I rejuvenated was not gassy to begin with and isn't gassy now, either. It'll be interesting to see the effects on the various tubes.
you could probably rig up a fixture with an old turntable and use one of those silicone baking pads. a hole is made in the silicone pad so just the glass is exposed. the turntable at 16rpm speed rotates the tube like a rotissery and the heat gun is stationary sitting on its base. the silicone pad would prevent heat from hitting the base. i could sketch it but dont know how to post a sketch. or how about a few seconds with a torch like used to sweat plumbing copper pipes. you would only need a few seconds
I can't find my 12AU7s that are weak. Right now I'm trying to remove the base of the #47 tube.
:Sounds like a good idea. As far as time goes, I'm not sure how much time is required. The tube sat in my oven for several hours, even as the oven cooled, so it was hot for a long time. I will have to see if the tube must be cooked for a while, or if it's only necessary to heat the getter for a moment. Baking the tube does drive gasses out of the metals.
:I can't find my 12AU7s that are weak. Right now I'm trying to remove the base of the #47 tube.
:T.
As far as acetone is concerned, I did get the base off of the #47. It is now baking. I let it reach 500 degrees and now it is cooling, so I'll check on it later. I wish I could find my dud miniature tubes because it'd be easy to bake a batch of them. :D I took pictures of the 47 in the tester, and I'm also working on the 80, which I also took pictures of before soaking. ...So when all is through, I'll have pictures of what I found, if it looks good. Otherwise I'll just post that it was a fluke.
I wish that there was good music on the radio so that I could really put these tubes through a test. All I have right now is Pandora, so I pipe that in.
Regarding the 47, though, I baked it, and guess what??!! It tests in the good region!!!!! I tested it with heavy current, too, and it drew well. This is vague, I know, but at its proper #3 current setting (EICO 625), the needle would barely move, and at the #4 setting, which is higher current at 200 volts (I believe), the needle might go about 1/2 an inch. Now it goes into the good on 3 and pegs on 4. I am re-baking it to see if I can make any improvements from here (with my first baking I merely let the oven reach 500, and then I turned it off). I wanted to leave the oven at 500 for 45 minutes (while my clothes dry), but I couldn't stand the fumes of the extremely hot oven, so I turned it off after 25 minutes. Still it has residual heat, so it'll be cooking for a while. I wish that I had a radio to try the 47 in.
Also check out the video of Clade Paillard who makes his own tubes - I believe he uses both a home-built IR oven and a magnetic induction flash..... http://paillard.claude.free.fr/
The reason why I selected baking is because it heats all items (especially glass) somewhat uniformly (heat transfer through a vacuum is minimal, but the internal elements do get warm eventually. It also heats the getter, which, as I recall, is only useful when hot (in early tubes with the bright silver). To prove the point, if you crack one of these tubes open, the getter will stay silver for years (doesn't react quickly). I read that when a tube is first made, it is baked while hooked to the evacuator. Baking drives out gasses, which both leaves through the evacuator, and also gets trapped in the getter as a chemical reaction. ...So I thought that I'd give baking a try, though I'm not evacuating the tubes.
Though they say that the oxide is poisoned from the filament being too hot, I also read something about excess gas in the early tubes that caused ion bombardment. I noticed that readings with these weak tubes were all over the place, climbing up, and then down, and then up, and down, at random times. While the filament oxide could be changing its bonding form, I feel that this is more from something very random like gas particles. Who knows, really. It's odd, but the first tube I tried became completely stable and much stronger after baking. I really need to do more trials though before I can surely prove anything.
I'll try to console myself with that factoid the next time I touch the rectifier tube in a set I'm working on...(LOL)
I have learned on several occasions that the glass on a tube gets hot enough to remove skin from fingertips, however the heat gets there. Also, hot tubes can look exactly like cool tubes.
:T.
You may consider wrapping the base of the tube with cotton or styrofoam to insulate it from the high temperature.
Another option would be to place the base in water, that will keep it below the boiling point.
I expect this will not work on weak tuning eyes, since their problem is phosphor displacement, not emission. I am thinking of trying it, though.
Best Regards,
Bill Grimm
As a follow-up for the #47, after further baking it now tests even better than before. Again, this is vague, as it is an emissions tester, but originally the meter read 600 and now it reads 800. The tube started out reading about 20-50. The original test was made with the base on. I did heat the pins before testing to be sure that the solder connections were good. The 'good' tests were made after the base was removed (after baking once and twice). I merely inserted the wires into the 7 pin socket on my tester. The most difficult connection to make was the filament, due to its current. All other connections were made well, and I ascertained this by throwing the various levers down from their up positions. Since they handle higher voltage at very low current, it will be easier to make a good connection.
I wonder what would happen if I baked the tube for an hour! I do notice a darkening of the glass as I bake the tube. Something is coating the inside of the glass. Perhaps it is getter or perhaps it is some other foreign material. It's an even smoky coating--very light. I'll have to search through my big box of tubes to find the weak 12AU7s. I think that they were Mullards. There are quite a few of them. It would be nice to batch test them. I thought that they'd be in my miniature tube box, but, as usual, they weren't (mess).
If so, is it possible to re-flash the getter on a weak tube?
Doug
:I baked a weak 6K6G tube, and it measures similar to before, and now is definitely gassy--purple glow, so I guess this method isn't a sure fix.
:T.
I have further read on the web that the getter actually doesn't vaporize again or become useful again (old silver getter, not the more modern barium, which is always active) unless it is raised to several thousand degrees, which might melt the glass, so I don't think that I was reactivating the getter. I don't know what I did, but with two tubes it worked very well. They have good solid tests over and over again, even after one of them has been used. A third tube, more modern, became gassy, and readings did not improve. However, with that tube I let it bake for over a 1/2 hour at 500 degrees, where-as the other tubes I only allowed to get up to 500, and then I turned off the oven. Whatever I am doing is definitely putting a brown deposit on the glass.
I have further read on the web that there are others out there who bake tubes, and have success for various reasons.
I only have one 1L6 tube, and it tests good, but if I can find other weak battery tubes, I will try to rejuvenate them.
I remember reading in a old radio electronics magazine about putting a weak tube in the oven at 200 degrees for several hours.
I have never tried it but the article claimed it worked.
