:Thanks for the answer, what is a solder sucker, never used one, are they readily available>?
Lou
:Use a solder sucker to remove all the solder from the base pins. Then solder thin extention wires to the crt leads. Feed the wires through the pins, and pull them all into place. Heat each wire to release the extention while soldering the crt leads to the pins. Use epoxy or super glue to hold the base on the crt. This takes a little time, but it can be done.
They rebuild picture tubes. I haven't used them, but they are the only one I know.
Best Regards,
Bill Grimm
::Hi Dave,
:: It seems you may have been suspecting the picture tube anyway. If so you may be interstd in http://www.hawkeyepicturetube.com/
:: They rebuild picture tubes. I haven't used them, but they are the only one I know.
::Best Regards,
::Bill Grimm
:Thanks everyone for the info. I am going to try and remove the solder, and put new wire into the socket, and then attach to the leads coming out of the tube, then glue it. When I just slide the wires into the openings on the base, which is no easy task, I might add, they dont make contact somewhere, because the tube filament doesnt light up. The frustrating thing about this is that this is a NOS 12LP$ that worked like NEW, and now I have to use the old dark tube with a brightener until I get this fixed.
