When I turn it on, the onrush current produces a low volume squeal from the speaker which quickly dies out but is replaced by an annoying crackle and unnaturally low output volume. The crackle is largely unaffected by the volume control.
I suspect silver migration from the IF transformer caps or -- more likely, I think -- some arcing in the audio output transformer.
Either scenario leaves me baffled as to how to fix it. If the caps are bad, what value silver micas should I replace them with? If the transformer's bad, how should I wire the replacement? (I have a nice Hammond push-pull output xfmr).
Her's a link to the schematic (last page):
http://www.nostalgiaair.org/Resources/630/M0017630.htm
I'm going to try the audio transformer substitution first, though. My Hammond transformer is a muklti-tap device, so I can play with impedances.
One reason I think it may be the transformer is (this is really embarrassing), upon reassembly in the refinished cabinet, I mismatched the speaker/field coil plug and the chassis jack and possibly zapped the transformer with the filed coil's supply voltage. Tjis cannopt be good fot eh transformer windings.
![]() Could be. . . . that the output transformer was damaged, they also don’t take too lightly to not having the speaker connected After looking at that sets top chassis it certainly seems that the set is utilizing the large full size I.F. cans. You might just confirm that for us. On those units I would expect the internal construction to be having the two variable cap sections be made on a large square ceramic bisque block at the top side. The manner of construction being alternate interlaced leaves of thin metal with each having a thin connector tab passing thru the ceramic and then sheets of mica placed between each sheet. A centrally placed pan head slotted screw is passing thru holes in the center of the leaves/mica spacers and Seems like the trouble came later on in the evolvement of I.F. transformers wherein they started making the transformers That then done away with the massive variable capacitance aspect and then they could be replaced with two physically small, fixed Seems like the later real fault with that procedure was with them utilizing compressive metallic contact areas to I certainly do believe that your unit is of such age, that it ISN’T even using that newer type of construction.
