2/13/2009 11:14:16 PMG. Berg(71104:0)
Hi all..I have a 1924 battery operated radio with two bad transformers ...Only one coil in each transformer is good. First...in transformers..is the inside coil the primary or secondary...Also I know that you can replace the transformer with a new one (inside the steel shell) but, I also am aware that you can use a resitor and a small cap. to do the same thing but not sure how to go about this or where to find the info...Could someone please help or direct me to where I may find info...THANK YOU...
2/13/2009 11:34:30 PMG. Berg...oops more info(71105:71104)
:Hi all..I have a 1924 battery operated radio with two bad transformers ...Only one coil in each transformer is good. First...in transformers..is the inside coil the primary or secondary...Also I know that you can replace the transformer with a new one (inside the steel shell) but, I also am aware that you can use a resitor and a small cap. to do the same thing but not sure how to go about this or where to find the info...Could someone please help or direct me to where I may find info...THANK YOU... OOPS...transformers have the name "All American" on them and are 3-1 ratio model R-12, audio frequency transformers
2/14/2009 12:38:41 AMPeter G. Balazsy(71106:71105)
http://www.antiqueradios.com/chrs/journal/transformers.html
2/14/2009 1:08:27 AMG. Berg... THANK YOU PETER!!(71108:71106)
:http://www.antiqueradios.com/chrs/journal/transformers.html
