Anatomy of a Specific ZENITH I.F. Transformer
2/11/2009 3:42:53 PMEdd
A referencing source for the . . . .
GREAT “SCOTT”…y !:
Relevant textual info to be added on a bit later. . . .
tune in again . . . . same time. . . . . same station
2/12/2009 1:16:37 PM. . . . . . . . .PARTE DEUX
TECHNO-INFORMATION:
For the benefit of anyone not yet familiar with the fact that there are also the same quirks that one experiences with the
" K-tran " style of ¾ inch I.F. transformer, also being present in some of the older, larger sized Zenith units.
Photo Referencing:
A. . . The top of the transformer. . ., it’s revealing the top of the cardboard coil form being somewhat dependent upon the
metal fold over in the top access adjustment hole, for centering / support of that coil form.
B… Shows the bottom of the transformer, with some short wire sprig-lets left intact for I.D .of the terminals and
particularly, the BLUE-RED reference indexing between terminals 1 and 8, which was also carried forward on
all of the associated mechanics inside the transformer, with use of a Blue Micro Tip Sharpie .
The crimps on the four sides of the bottom of the transformer hold the bottom fiberboard plate in place. Clipping one side
as shown, will leave tabs that can be swung outwards as shown and later be swung back in place to re-lock the bottom
square fiberboard plate in position.
Seems like those tabs tend to have a metal fatigue lifespan of 2 ¾ re bends, just in case you are needing a later accessing .
C. . . The view of the transformer proper, this is just about the point to make a drawing of the start /finish of the two coils
windings and the connections to their terminals on the fiberboard term disc. Unconnect all 4 wire ends and the coil will
then just lift out of the round brass clamp. Set the coil form aside for safety.
D. . . This is showing the blow-up of the disassembly of the bottom wafer, its terminals, the internal mica dielectric disc,
and the bottom round fiberboard disc/ pressure plate, round brass coil clamp, keyed brass screw and the clamping nut.
E. . . Removing the mica disc, reveals the contacts associative with its interfacing. This is also about the point where you
can observe that the inner "petals" are somewhat responsible for the creating of a support of the terminals that are passing
thru slots in the fiber disk. On a K’tran conversion one could gut all of the micas and still leave the terminals being well
supported
by the surround plastic molding. However, in this transformers terminal mechanical support situation, one needs to:
1. . . Re utilize a cleaned , de oxidized, inspected mica dielectric disc, . . . or
2. . .Clip the petals and micro-epoxy the terminals for support of the wiring side and opposite coil wire connection side of the
coils terminals. . .or
3. . . Replace the mica disc with an insulator / dielectric /spacer disc, then reassemble and ascertain the value of externally
installed silver micas required to resonate the coils at 455, with the internal slugs being positioned ≈ ½ of a slugs width outwards,
from its being centered within its coil.
F. . . This is a view of the mica element and its silver deposition areas. Check the blue /red index bar and find the terminal just
to its left at the top left corner of the pic and it will be terminal #1 and connects to the "petal" that is obscured by the mica insulator
but its connective area is the silvered area that is on the bottom side of the disc and is outlined in BLUE.
Just above that area the companion terminal 8 is connected and you can see its "petal" that is pressing down to the RED outlined
mark up.
Now look over to the right half of the disc and notice that the bottom. . . .obscured. . ."petals" are connecting to that YELLOW outlined
silvering that encompasses ≈ three quarters of the area of the bottom side of the disc.
Now, in looking topside at the right top hand corners "petal", one can see the MAGENTA outlining of its silvered contact area.
The last silvering is located at the very bottom of the pic and is shown as the GREEN outlining and contacts to its "petal" contactor.
Contact Areas Summarization:
The top left corner area is the "≈ 120 "µµfd capacitance that resonates the plate circuitry of the I.F. transformer.
Referring to photo F, that would be the RED and BLUE portions.
The right top corner area is the "≈ 120 "µµfd capacitance that resonates the secondary circuitry of the I.F. transformer.
Referring to photo F, that would be the top of the pics YELLOW and MAGENTA portions.
Lastly, the bottom center terminal area is the "≈ 180 "µµfd capacitance for the RF stripping / “tweet” filter of the detector
circuitry.
Referring to photo F, that would be the bottom of the pics massive YELLOW and smaller GREEN portion.
With that YELLOW
section being connected to the cold portion of the detector secondary coils winding.
G. . . Depicts a one time use of an insulator of drafting film for the replacement of a mica insulator.
H . . A side view of a re-clamped unit, only needing the coil assembly and its soldering of coil wires to its terminals.
J. . .Top side and bottom sides of the mica disc:
A superimposed / combinational infrared /x-ray photomicrograph :
The x-ray aspect being relevant to the thickness of the materiel-- the infrared aspect being relevant to the emissivity
when being heat flooded. Both are then being displaying out as shades of grey. Take particular note of the minute silver
traces present around the extreme periphery of the disc.
Its showing the points of maximum contact pressure (within the red circles) of this assembly in its past history.
Actually, there was a minimal surfactal contact area being present !. . . .instead of the "petals" making a broad surface
contact area.
Thassit. . . .
If any add ons. . .info. . . .comments. . . .please scroll on down and place them on at the very tail of the thread. . . . to keep
the header illustration intact.
2/12/2009 2:36:53 PMRene
Great post! I've messed with a few transformers like this. One had a cracked wafer such that no audio output was making it to the volume control but some audio was leaking into the AF amp anyway. The set exhibited low volume and unresponsive to the volume control.
I'm still trying to figure out the capacitors/circuitry on the secondary of this type of transformer...it's like 3 capacitors in series. I know one is the resonant cap across the secondary winding. You've described one of the extra lead-outs as an "RF stripping/tweet" filter. I have a few radio textbooks but none describe this circuitry. Enquiring minds want to know.
You used 120 uuF caps for the resonant caps @455 kHz...what would be a good cap for 265 kHz? One half or double the 120?
:TECHNO-INFORMATION:
:For the benefit of anyone not yet familiar with the fact that there are also the same quirks that one experiences with the
: " K-tran " style of ¾ inch I.F. transformer, also being present in some of the older, larger sized Zenith units.
:Photo Referencing:
:A. . . The top of the transformer. . ., it’s revealing the top of the cardboard coil form being somewhat dependent upon the
:metal fold over in the top access adjustment hole, for centering / support of that coil form.
:B… Shows the bottom of the transformer, with some short wire sprig-lets left intact for I.D .of the terminals and
: particularly, the BLUE-RED reference indexing between terminals 1 and 8, which was also carried forward on
:all of the associated mechanics inside the transformer, with use of a Blue Micro Tip Sharpie .
:The crimps on the four sides of the bottom of the transformer hold the bottom fiberboard plate in place. Clipping one side
:as shown, will leave tabs that can be swung outwards as shown and later be swung back in place to re-lock the bottom
: square fiberboard plate in position.
:Seems like those tabs tend to have a metal fatigue lifespan of 2 ¾ re bends, just in case you are needing a later accessing .
:C. . . The view of the transformer proper, this is just about the point to make a drawing of the start /finish of the two coils
: windings and the connections to their terminals on the fiberboard term disc. Unconnect all 4 wire ends and the coil will
:then just lift out of the round brass clamp. Set the coil form aside for safety.
:D. . . This is showing the blow-up of the disassembly of the bottom wafer, its terminals, the internal mica dielectric disc,
: and the bottom round fiberboard disc/ pressure plate, round brass coil clamp, keyed brass screw and the clamping nut.
:E. . . Removing the mica disc, reveals the contacts associative with its interfacing. This is also about the point where you
:can observe that the inner "petals" are somewhat responsible for the creating of a support of the terminals that are passing
:thru slots in the fiber disk. On a K’tran conversion one could gut all of the micas and still leave the terminals being well
:supported
:by the surround plastic molding. However, in this transformers terminal mechanical support situation, one needs to:
:1. . . Re utilize a cleaned , de oxidized, inspected mica dielectric disc, . . . or
:2. . .Clip the petals and micro-epoxy the terminals for support of the wiring side and opposite coil wire connection side of the
:coils terminals. . .or
:3. . . Replace the mica disc with an insulator / dielectric /spacer disc, then reassemble and ascertain the value of externally
:installed silver micas required to resonate the coils at 455, with the internal slugs being positioned ≈ ½ of a slugs width outwards,
:from its being centered within its coil.
:F. . . This is a view of the mica element and its silver deposition areas. Check the blue /red index bar and find the terminal just
:to its left at the top left corner of the pic and it will be terminal #1 and connects to the "petal" that is obscured by the mica insulator
: but its connective area is the silvered area that is on the bottom side of the disc and is outlined in BLUE.
: Just above that area the companion terminal 8 is connected and you can see its "petal" that is pressing down to the RED outlined
: mark up.
:Now look over to the right half of the disc and notice that the bottom. . . .obscured. . ."petals" are connecting to that YELLOW outlined
: silvering that encompasses ≈ three quarters of the area of the bottom side of the disc.
:Now, in looking topside at the right top hand corners "petal", one can see the MAGENTA outlining of its silvered contact area.
:The last silvering is located at the very bottom of the pic and is shown as the GREEN outlining and contacts to its "petal" contactor.
:Contact Areas Summarization:
:The top left corner area is the "≈ 120 "µµfd capacitance that resonates the plate circuitry of the I.F. transformer.
:Referring to photo F, that would be the RED and BLUE portions.
:The right top corner area is the "≈ 120 "µµfd capacitance that resonates the secondary circuitry of the I.F. transformer.
: Referring to photo F, that would be the top of the pics YELLOW and MAGENTA portions.
:Lastly, the bottom center terminal area is the "≈ 180 "µµfd capacitance for the RF stripping / “tweet” filter of the detector
:circuitry.
: Referring to photo F, that would be the bottom of the pics massive YELLOW and smaller GREEN portion.
:With that YELLOW
:section being connected to the cold portion of the detector secondary coils winding.
:G. . . Depicts a one time use of an insulator of drafting film for the replacement of a mica insulator.
:H . . A side view of a re-clamped unit, only needing the coil assembly and its soldering of coil wires to its terminals.
:J. . .Top side and bottom sides of the mica disc:
:A superimposed / combinational infrared /x-ray photomicrograph :
: The x-ray aspect being relevant to the thickness of the materiel-- the infrared aspect being relevant to the emissivity
: when being heat flooded. Both are then being displaying out as shades of grey. Take particular note of the minute silver
:traces present around the extreme periphery of the disc.
:Its showing the points of maximum contact pressure (within the red circles) of this assembly in its past history.
:Actually, there was a minimal surfactal contact area being present !. . . .instead of the "petals" making a broad surface
:contact area.
:Thassit. . . .
:If any add ons. . .info. . . .comments. . . .please scroll on down and place them on at the very tail of the thread. . . . to keep
: the header illustration intact.
2/17/2009 5:11:44 PMSCOTTY
:Great post! I've messed with a few transformers like this. One had a cracked wafer such that no audio output was making it to the volume control but some audio was leaking into the AF amp anyway. The set exhibited low volume and unresponsive to the volume control.
:I'm still trying to figure out the capacitors/circuitry on the secondary of this type of transformer...it's like 3 capacitors in series. I know one is the resonant cap across the secondary winding. You've described one of the extra lead-outs as an "RF stripping/tweet" filter. I have a few radio textbooks but none describe this circuitry. Enquiring minds want to know.
:You used 120 uuF caps for the resonant caps @455 kHz...what would be a good cap for 265 kHz? One half or double the 120?
::TECHNO-INFORMATION:
::For the benefit of anyone not yet familiar with the fact that there are also the same quirks that one experiences with the
:: " K-tran " style of ¾ inch I.F. transformer, also being present in some of the older, larger sized Zenith units.
::Photo Referencing:
::A. . . The top of the transformer. . ., it’s revealing the top of the cardboard coil form being somewhat dependent upon the
::metal fold over in the top access adjustment hole, for centering / support of that coil form.
::B… Shows the bottom of the transformer, with some short wire sprig-lets left intact for I.D .of the terminals and
:: particularly, the BLUE-RED reference indexing between terminals 1 and 8, which was also carried forward on
::all of the associated mechanics inside the transformer, with use of a Blue Micro Tip Sharpie .
::The crimps on the four sides of the bottom of the transformer hold the bottom fiberboard plate in place. Clipping one side
::as shown, will leave tabs that can be swung outwards as shown and later be swung back in place to re-lock the bottom
:: square fiberboard plate in position.
::Seems like those tabs tend to have a metal fatigue lifespan of 2 ¾ re bends, just in case you are needing a later accessing .
::C. . . The view of the transformer proper, this is just about the point to make a drawing of the start /finish of the two coils
:: windings and the connections to their terminals on the fiberboard term disc. Unconnect all 4 wire ends and the coil will
::then just lift out of the round brass clamp. Set the coil form aside for safety.
::D. . . This is showing the blow-up of the disassembly of the bottom wafer, its terminals, the internal mica dielectric disc,
:: and the bottom round fiberboard disc/ pressure plate, round brass coil clamp, keyed brass screw and the clamping nut.
::E. . . Removing the mica disc, reveals the contacts associative with its interfacing. This is also about the point where you
::can observe that the inner "petals" are somewhat responsible for the creating of a support of the terminals that are passing
::thru slots in the fiber disk. On a K’tran conversion one could gut all of the micas and still leave the terminals being well
::supported
::by the surround plastic molding. However, in this transformers terminal mechanical support situation, one needs to:
::1. . . Re utilize a cleaned , de oxidized, inspected mica dielectric disc, . . . or
::2. . .Clip the petals and micro-epoxy the terminals for support of the wiring side and opposite coil wire connection side of the
::coils terminals. . .or
::3. . . Replace the mica disc with an insulator / dielectric /spacer disc, then reassemble and ascertain the value of externally
::installed silver micas required to resonate the coils at 455, with the internal slugs being positioned ≈ ½ of a slugs width outwards,
::from its being centered within its coil.
::F. . . This is a view of the mica element and its silver deposition areas. Check the blue /red index bar and find the terminal just
::to its left at the top left corner of the pic and it will be terminal #1 and connects to the "petal" that is obscured by the mica insulator
:: but its connective area is the silvered area that is on the bottom side of the disc and is outlined in BLUE.
:: Just above that area the companion terminal 8 is connected and you can see its "petal" that is pressing down to the RED outlined
:: mark up.
::Now look over to the right half of the disc and notice that the bottom. . . .obscured. . ."petals" are connecting to that YELLOW outlined
:: silvering that encompasses ≈ three quarters of the area of the bottom side of the disc.
::Now, in looking topside at the right top hand corners "petal", one can see the MAGENTA outlining of its silvered contact area.
::The last silvering is located at the very bottom of the pic and is shown as the GREEN outlining and contacts to its "petal" contactor.
::Contact Areas Summarization:
::The top left corner area is the "≈ 120 "µµfd capacitance that resonates the plate circuitry of the I.F. transformer.
::Referring to photo F, that would be the RED and BLUE portions.
::The right top corner area is the "≈ 120 "µµfd capacitance that resonates the secondary circuitry of the I.F. transformer.
:: Referring to photo F, that would be the top of the pics YELLOW and MAGENTA portions.
::Lastly, the bottom center terminal area is the "≈ 180 "µµfd capacitance for the RF stripping / “tweet” filter of the detector
::circuitry.
:: Referring to photo F, that would be the bottom of the pics massive YELLOW and smaller GREEN portion.
::With that YELLOW
::section being connected to the cold portion of the detector secondary coils winding.
::G. . . Depicts a one time use of an insulator of drafting film for the replacement of a mica insulator.
::H . . A side view of a re-clamped unit, only needing the coil assembly and its soldering of coil wires to its terminals.
::J. . .Top side and bottom sides of the mica disc:
::A superimposed / combinational infrared /x-ray photomicrograph :
:: The x-ray aspect being relevant to the thickness of the materiel-- the infrared aspect being relevant to the emissivity
:: when being heat flooded. Both are then being displaying out as shades of grey. Take particular note of the minute silver
::traces present around the extreme periphery of the disc.
::Its showing the points of maximum contact pressure (within the red circles) of this assembly in its past history.
::Actually, there was a minimal surfactal contact area being present !. . . .instead of the "petals" making a broad surface
::contact area.
::Thassit. . . .
::If any add ons. . .info. . . .comments. . . .please scroll on down and place them on at the very tail of the thread. . . . to keep
:: the header illustration intact.
::73's de Edd
::EDD: I just ran across this thread after posting to your original thread.Thanks for the great information.If you check the original thread any information to my question would be great.Thanks again.
2/17/2009 8:58:45 PMMarv Nuce
Scotty,
If 2 caps in series are placed in parallel with the winding, then fed at the cap junction, its equivalent to a tap on the winding. Typically this technique is used to feed a transformer with a lower impedamce device vs feeding the top and lowering the "Q", which would also broaden its bandwidth.
::Great post! I've messed with a few transformers like this. One had a cracked wafer such that no audio output was making it to the volume control but some audio was leaking into the AF amp anyway. The set exhibited low volume and unresponsive to the volume control.
::I'm still trying to figure out the capacitors/circuitry on the secondary of this type of transformer...it's like 3 capacitors in series. I know one is the resonant cap across the secondary winding. You've described one of the extra lead-outs as an "RF stripping/tweet" filter. I have a few radio textbooks but none describe this circuitry. Enquiring minds want to know.
::You used 120 uuF caps for the resonant caps @455 kHz...what would be a good cap for 265 kHz? One half or double the 120?
:::TECHNO-INFORMATION:
:::For the benefit of anyone not yet familiar with the fact that there are also the same quirks that one experiences with the
::: " K-tran " style of ¾ inch I.F. transformer, also being present in some of the older, larger sized Zenith units.
:::Photo Referencing:
:::A. . . The top of the transformer. . ., it’s revealing the top of the cardboard coil form being somewhat dependent upon the
:::metal fold over in the top access adjustment hole, for centering / support of that coil form.
:::B… Shows the bottom of the transformer, with some short wire sprig-lets left intact for I.D .of the terminals and
::: particularly, the BLUE-RED reference indexing between terminals 1 and 8, which was also carried forward on
:::all of the associated mechanics inside the transformer, with use of a Blue Micro Tip Sharpie .
:::The crimps on the four sides of the bottom of the transformer hold the bottom fiberboard plate in place. Clipping one side
:::as shown, will leave tabs that can be swung outwards as shown and later be swung back in place to re-lock the bottom
::: square fiberboard plate in position.
:::Seems like those tabs tend to have a metal fatigue lifespan of 2 ¾ re bends, just in case you are needing a later accessing .
:::C. . . The view of the transformer proper, this is just about the point to make a drawing of the start /finish of the two coils
::: windings and the connections to their terminals on the fiberboard term disc. Unconnect all 4 wire ends and the coil will
:::then just lift out of the round brass clamp. Set the coil form aside for safety.
:::D. . . This is showing the blow-up of the disassembly of the bottom wafer, its terminals, the internal mica dielectric disc,
::: and the bottom round fiberboard disc/ pressure plate, round brass coil clamp, keyed brass screw and the clamping nut.
:::E. . . Removing the mica disc, reveals the contacts associative with its interfacing. This is also about the point where you
:::can observe that the inner "petals" are somewhat responsible for the creating of a support of the terminals that are passing
:::thru slots in the fiber disk. On a K’tran conversion one could gut all of the micas and still leave the terminals being well
:::supported
:::by the surround plastic molding. However, in this transformers terminal mechanical support situation, one needs to:
:::1. . . Re utilize a cleaned , de oxidized, inspected mica dielectric disc, . . . or
:::2. . .Clip the petals and micro-epoxy the terminals for support of the wiring side and opposite coil wire connection side of the
:::coils terminals. . .or
:::3. . . Replace the mica disc with an insulator / dielectric /spacer disc, then reassemble and ascertain the value of externally
:::installed silver micas required to resonate the coils at 455, with the internal slugs being positioned ≈ ½ of a slugs width outwards,
:::from its being centered within its coil.
:::F. . . This is a view of the mica element and its silver deposition areas. Check the blue /red index bar and find the terminal just
:::to its left at the top left corner of the pic and it will be terminal #1 and connects to the "petal" that is obscured by the mica insulator
::: but its connective area is the silvered area that is on the bottom side of the disc and is outlined in BLUE.
::: Just above that area the companion terminal 8 is connected and you can see its "petal" that is pressing down to the RED outlined
::: mark up.
:::Now look over to the right half of the disc and notice that the bottom. . . .obscured. . ."petals" are connecting to that YELLOW outlined
::: silvering that encompasses ≈ three quarters of the area of the bottom side of the disc.
:::Now, in looking topside at the right top hand corners "petal", one can see the MAGENTA outlining of its silvered contact area.
:::The last silvering is located at the very bottom of the pic and is shown as the GREEN outlining and contacts to its "petal" contactor.
:::Contact Areas Summarization:
:::The top left corner area is the "≈ 120 "µµfd capacitance that resonates the plate circuitry of the I.F. transformer.
:::Referring to photo F, that would be the RED and BLUE portions.
:::The right top corner area is the "≈ 120 "µµfd capacitance that resonates the secondary circuitry of the I.F. transformer.
::: Referring to photo F, that would be the top of the pics YELLOW and MAGENTA portions.
:::Lastly, the bottom center terminal area is the "≈ 180 "µµfd capacitance for the RF stripping / “tweet” filter of the detector
:::circuitry.
::: Referring to photo F, that would be the bottom of the pics massive YELLOW and smaller GREEN portion.
:::With that YELLOW
:::section being connected to the cold portion of the detector secondary coils winding.
:::G. . . Depicts a one time use of an insulator of drafting film for the replacement of a mica insulator.
:::H . . A side view of a re-clamped unit, only needing the coil assembly and its soldering of coil wires to its terminals.
:::J. . .Top side and bottom sides of the mica disc:
:::A superimposed / combinational infrared /x-ray photomicrograph :
::: The x-ray aspect being relevant to the thickness of the materiel-- the infrared aspect being relevant to the emissivity
::: when being heat flooded. Both are then being displaying out as shades of grey. Take particular note of the minute silver
:::traces present around the extreme periphery of the disc.
:::Its showing the points of maximum contact pressure (within the red circles) of this assembly in its past history.
:::Actually, there was a minimal surfactal contact area being present !. . . .instead of the "petals" making a broad surface
:::contact area.
:::Thassit. . . .
:::If any add ons. . .info. . . .comments. . . .please scroll on down and place them on at the very tail of the thread. . . . to keep
::: the header illustration intact.
:::73's de Edd
:::EDD: I just ran across this thread after posting to your original thread.Thanks for the great information.If you check the original thread any information to my question would be great.Thanks again.
