It almost works, just need to be re-tuned.
I have not tested the clock yet.
Thanks in advance for any help
I've sent you the Motorola 5C1 schematic from Rider. There is additional information in Rider Vol #21 and Sam's Photofact #116. You may be able to get this information through your local library. Sam's can be reached at 800-428-7267.
: I am looking for the schematics an tuning steps for a Motorola clock radio.
: Inside was a small manual reading "model 5C4, 5C5 or 5C6.
: The back panel says: Model 5C Serial number 19327
: and at the bottom, in small numbers: 24K601023
: The metal chassis is stamped with the number: 7A478118
: the 5 tubes are: 12BE6, 12BA6, 12AT6, 5OC5 and 35W4
: there is a patent label with a rubber stamp: Nov 15, 1950
: (as far as I can read)
: It almost works, just need to be re-tuned.
: I have not tested the clock yet.
: Thanks in advance for any help
thanks a lot for a quick reply
I'm, once more, one of many happy guys you help tirelessly
