Inspect your set carefully to see how it is set up in the power supply area and whether it has been modified. If it's still set up to use dual 6X5s, it would be a good idea to replace the 6X5s with two NOS 6X5s, preferably ones that have the X-shaped plate configuration. You should also fuse the power xfmr primary and maybe even the center-tap of the high-voltage secondary winding.
If you will be using dual 6X5s, I would install a CL-90 current limiter in the xfmr primary ckt. This will cut down on turn-on surge, and reduce wear and tear on the rectifier tubes.
Doug
http://www.oldradioparts.com/pg2a23e.htm
:you can probably find a power transformer here:
:http://www.oldradioparts.com/pg2a23e.htm
