To help identify the chassis, and hopefully identify a schematic, the photos can be found at http://groups.google.ca/group/vintage-radio-pic/web/pictures
Agree with David. A photo of your chassis in the cabinet would be a big help in possibly identifying your radio. Noticed that it includes a Marconi tube and your photo link has a .ca tag on it. By any chance did you buy this radio in Canada?
If it is a Canadian radio after 1938 you won't find a corresponding Canadian RCC schematic on this site. American and Canadian brands often used totally different chassis.
Try to post a photo with the chassis in the cabinet
Best regards
Ken
Cabinet picture posted to site http://groups.google.com/group/vintage-radio-pic/
it's not a great picture, I will post a better one....
Gareth
Anyone recognize the cabinet in Gareth's link.
http://vintage-radio-pic.googlegroups.com/web/IMG_4628.JPG?gda=zwOzGT4AAACBzSMMICwKgWMRXqBweQXQAhNIN2odoNfPZ9olPwCzfrSccv2wOCb4MGanYML9TeDjsKXVs-X7bdXZc5buSfmx
Ken
When I initially saw that chassis, I was thinking of the manufacturers that I had seen using that shade of orange dial scale,
along with it using a distinctive vertical dial arrangement. I then researched several possibilities, but, found none,
With the tube lineup I tend to want to date the chassis as circa 35-40.
With your posting of the cabinet, that tends to reek of being an older vintage cabinet, in inspection of the inside of the cabinet around the dial escutcheon plate, does it suggest any cutting on the cabinet in order to fit in that unit ? Along with any difference in the aging of the wood after being cut as compared to the normal cuts that are on the original cabinetry ?
Also I see the right angle mounting brackets used at the sides of the chassis, your bottom view doesn’t let me see all of the
periphery of the bottom lip, any chance that there were other mounting holes in it for its previous mounting?
Apparently, the far right control is the tone control for the set, but with an attached unused switch section, on its rear. . .BUT. .
just in its near proximity I see an Aerovox paper capacitor of CANADIAN manufacture sourcing, I see that there are others also.
Isn’t that a steel chassis with a very light black wrinkle finish on it ?
My second attempt was to closely observe that distinctive vertical dials, dial cord stringing and compare it to all of Sams
dial cord stringing arrangements , but that also didn’t make a conclusion.
Could make out the part number of the AF output transformer, as well as the IF 2-2 and IF 1-1 transformer numbers and
the SMOOOOOOOKERS in the house. Couldn’t make out any top ID stampings on that Hi i i igh - boy power transformer.
http://members.tripod.com/~gabevee/majest90.html
No doubt that chassis was probably installed along time ago. The dial smacks of something that was used in a radio phono unit. It's almost like he remounted the the dial and components on another metal chassis
to compensate to fit the old cabinet. Whoever did it did a decent job and the radio is still presentable the way it is.
Best regards
Ken
:It does look like a 30's Philco cabinet. The knobs sure look wrong, as well the vertical dial. The tube line up seems not of that vintage. Not a bad fake it though. I would put some wood knobs on it.
