Precision Apparatus 960 transistor tester
11/25/1998 4:23:20 PMRichard Reedel
I am looking for schematics, service info, or any information I can find on Precision Apparatus Co. model 960 transistor and crystal diode tester.
11/26/1998 6:54:09 AMDon Black
: I am looking for schematics, service info, or any information I can find on Precision Apparatus Co. model 960 transistor and crystal diode tester.
Hi Richard,
I'm looking for the same information for a B&K transistor radio analyst model 960. This can test transistors in or out of circuit, has an RF service oscillator, 250 kHz to 2.2 mHz and a 0 to 12 volt power supply in 1.5 volt steps. Is this the same as your tester and if so could I please get a copy of any information that you get? Mine has a burnet out power transformer and I need to know the secondary voltage to find a replacement, also operating instructions. Good luck, Don.
11/26/1998 9:56:54 AMNorm Leal
: : I am looking for schematics, service info, or any information I can find on Precision Apparatus Co. model 960 transistor and crystal diode tester.
: Hi Richard,
: I'm looking for the same information for a B&K transistor radio analyst model 960. This can test transistors in or out of circuit, has an RF service oscillator, 250 kHz to 2.2 mHz and a 0 to 12 volt power supply in 1.5 volt steps. Is this the same as your tester and if so could I please get a copy of any information that you get? Mine has a burnet out power transformer and I need to know the secondary voltage to find a replacement, also operating instructions. Good luck, Don.
Hi Don & Richard
The Electronic Industry Telephone Directory lists B&K Precision Corp. They are located at 1031 Segovia Cir. Placentia, CA 92870. The phone 800-462-9832, fax 714-237-9214. Don, I don't think 800 phone numbers can be called from Australia.
12/18/1998 6:12:20 PMRichard Reedel
: : : I am looking for schematics, service info, or any information I can find on Precision Apparatus Co. model 960 transistor and crystal diode tester.
: : Hi Richard,
: : I'm looking for the same information for a B&K transistor radio analyst model 960. This can test transistors in or out of circuit, has an RF service oscillator, 250 kHz to 2.2 mHz and a 0 to 12 volt power supply in 1.5 volt steps. Is this the same as your tester and if so could I please get a copy of any information that you get? Mine has a burnet out power transformer and I need to know the secondary voltage to find a replacement, also operating instructions. Good luck, Don.
: Hi Don & Richard
: The Electronic Industry Telephone Directory lists B&K Precision Corp. They are located at 1031 Segovia Cir. Placentia, CA 92870. The phone 800-462-9832, fax 714-237-9214. Don, I don't think 800 phone numbers can be called from Australia.
: Norm
Thanks for your help Don, I printed out the schematic and spec sheet you sent. They turned out great. All I have to do now is sit down and trouble shoot the Precision Apparratus 960!
Thanks again for your help,
Richard Reedel
5/24/2000 10:10:08 PMEdward Barile
: : : : I am looking for schematics, service info, or any information I can find on Precision Apparatus Co. model 960 transistor and crystal diode tester.
: : : Hi Richard,
: : : I'm looking for the same information for a B&K transistor radio analyst model 960. This can test transistors in or out of circuit, has an RF service oscillator, 250 kHz to 2.2 mHz and a 0 to 12 volt power supply in 1.5 volt steps. Is this the same as your tester and if so could I please get a copy of any information that you get? Mine has a burnet out power transformer and I need to know the secondary voltage to find a replacement, also operating instructions. Good luck, Don.
: : Hi Don & Richard
: : The Electronic Industry Telephone Directory lists B&K Precision Corp. They are located at 1031 Segovia Cir. Placentia, CA 92870. The phone 800-462-9832, fax 714-237-9214. Don, I don't think 800 phone numbers can be called from Australia.
: : Norm
: Thanks for your help Don, I printed out the schematic and spec sheet you sent. They turned out great. All I have to do now is sit down and trouble shoot the Precision Apparratus 960!
: Thanks again for your help,
: Richard Reedel
Hi. Did you guys knwo you can get schematics and manuals from A. Tannenbaum. I sent away for a manual for my Precision Apparatus Model 120 VOM.
9/20/2002 6:38:10 AMCharles
:: I am looking for schematics, service info, or any information I can find on Precision Apparatus Co. model 960 transistor and crystal diode tester.
:Hi Richard,
9/20/2002 6:39:22 AMCharles
I am also looking for the manual for the B&K 960.
Could you email the same copy?
Charles
11/26/1998 8:39:42 AMDon Black
Hello again, Richard,
I've just found that I have a copy of the parts list and schematic for a precision model 960 semiconductor tester and it's quite different to my B&K 960. I'll try and scan it tomorrow with a friends scanner and if successful I'll email it to you. Don.
2/4/2000 7:32:45 AMjames donaldson
hello i am having difficulity finding any information
i hopr you can help me
2/4/2000 7:32:57 AMjames donaldson
i hope you can help me
5/10/2000 12:46:55 AMGirish Gautam
5/24/2000 10:13:32 PMEdward Barile
Look at http://www.agtannenbaum.com/ for schematics and manuals. You can call them too and they are very helpful.
5/24/2000 10:16:08 PMEdward Barile
Here is their listing for Precision:
PRECISION 1A1 ULTRA SIGNAL GEN. (NO SCH.) OP $6.00
PRECISION 10-12/10-15 TUBE TESTERS OP $11.00
PRECISION 10-20/10-22/10-54 TUBE TESTERS OP $11.00
PRECISION 10-12/10-15 TUBE TEST DATA DATA $15.00
PRECISION 10-20/10-22/10-54 TUBE TESTERS DATA $15.00
PRECISION 85 VOM OP $9.00
PRECISION 120 VOM OP $9.00
PRECISION 612 TUBE TESTER OP $11.00
PRECISION 612/614/620/65TUBE TEST DATA DATA $17.00
PRECISION 640 TUBE TESTER OP $11.00
PRECISION 640/660 SUPPLEMETARY TUBE DATA DATA $15.00
PRECISION 654 TUBE TESTER OP $14.00es
PRECISION 660 TUBE & TRANSISTOR TESTER OP $17.00
PRECISION 660 TRANSISTOR & CRYSTAL TEST DADATA $30.00
PRECISION 852 SERIES VOM OP $11.00
PRECISION 910-954 TUBE TESTER OP $14.00es
PRECISION 910-954 TUBE TESTER SUPPLEMENT DATA $17.00es
PRECISION 910-954 TEST DATA THROUGH NOV-76 DATA $17.00
PRECISION 960 TRANSISTOR/DIODE TESTER OP $14.00
PRECISION 960 CRYSTAL DIODE TEST DATA DATA $11.00
PRECISION 1950 CATALOG DATA $6.00
PRECISION 1953 CATALOG DATA $6.00
PRECISION CB-26 CAPACITOR TESTER OP $14.00
PRECISION E-200 SIG.GEN OP.INST OP $14.00
PRECISION E-200C SIG.GEN OP.INST OP $14.00es
PRECISION E-200C SER. BY SIG. SUBS. 92pgs OP $24.00
PRECISION E-200C new 1967 VERSION SIG GENERATOR OP $14.00es
PRECISION E 300 SINE SQUARE WAVE GENERATOR OP $14.00
PRECISION E-310 SINE SQUARE WAVE GENERATOR OP $14.00
PRECISION E-400 SWEEP GENERATOR OP $14.00
PRECISION ES 500 OSCILLOGRAPH OP $11.00
PRECISION ES 500A OSCILLOGRAPH OP $17.00
PRECISION ES-550 OSCILLOSCOPE OP $11.00
PRECISION EV-20 VTVM OP $11.00
PRECISION LINE VARIOUS AD $3.50
PRECISION RF-10A TEST PROBE OP $8.00
PRECISION SP-5 OSCILLOSCOPE PROBES OP $6.00
6/28/2000 9:59:21 PMHoracio Laureda
: I am looking for schematics, service info, or any information I can find on Precision Apparatus Co. model 912
updated charts of probe
sincerily Horacio Laureda
9/19/2000 6:35:21 PMjames winters
: : I am looking for schematics, service info, or any information I can find on Precision Apparatus Co. model 912
: updated charts of probe
: sincerily Horacio Laureda
I have a old copied schematic for the precision 912 tube tester. Do you have a tube roll chart for same? Maybe we can swap. copy for copy
8/24/2001 12:13:00 AMJOHN LAUREDA
