Grunow 670 schematic
2/1/2009 2:35:56 PMJF
Hi
Does anyone know where I can find a detailed schematic for a Grunow 670 tombstone, some early repair work has got me confused as to where electrolytics go..Thanks Jeff
2/1/2009 3:17:28 PMCarl T
:Hi
:Does anyone know where I can find a detailed schematic for a Grunow 670 tombstone, some early repair work has got me confused as to where electrolytics go..Thanks Jeff
Jeff,
If it's a Grigsby Grunow, you can find the schematic here:
http://www.nostalgiaair.org/PagesByModel/762/M0008762.pdf
Carl T
2/1/2009 3:23:03 PMCarl T
::Hi
::Does anyone know where I can find a detailed schematic for a Grunow 670 tombstone, some early repair work has got me confused as to where electrolytics go..Thanks Jeff
:Jeff,
:If it's a Grigsby Grunow, you can find the schematic here:
:http://www.nostalgiaair.org/PagesByModel/762/M0008762.pdf
Actually, that is for a model 370.
For the 670 try this:
http://www.nostalgiaair.org/PagesByModel/571/M0010571.pdf
:Carl T
2/1/2009 3:42:14 PMJF
It looks like it could be right however what I really need is: a cap list. The electrolytic caps are in a box, I believe there are 4 of them, someone replaced a couple of the caps by cutting wires on the box and replacing. I think only one or two has been replaced. (an old repair at least one paper cap installed) I guess what would help along with the schematic is a cap list s o I can tie values to cap numbers.
:::Does anyone know where I can find a detailed schematic for a Grunow 670 tombstone, some early repair work has got me confused as to where electrolytics go..Thanks Jeff
::Jeff,
::If it's a Grigsby Grunow, you can find the schematic here:
::http://www.nostalgiaair.org/PagesByModel/762/M0008762.pdf
:Actually, that is for a model 370.
:For the 670 try this:
:http://www.nostalgiaair.org/PagesByModel/571/M0010571.pdf
::Carl T
