Radiola 18 filter reactor
2/1/2009 9:31:19 AMMark
Good moring!
I'm working on a Radiola 18.
Two of the cans on the power unit were loose. Obviouslly someone had
been tampering with it.
This unit is packed with the black tar/wax.
What does the this unit do?
I checked the units inside the block with my meter and got a reading
on all four wires.
I'm newbie when it comes to the Radiola 18. The schemetic doesn't help.
Mark
2/1/2009 10:14:09 AMMmakazoo
Mark: My Westinghouse WR-8 uses the same chassis as the Radiola 82 and the filter reactor is simply a choke. Resistance values are given on the schematic so that you can check it with a meter to see if it is shorted or open. The filter reactor along with the filter caps helps to smooth out the DC power and reduce hum. Mark from Kalamazoo
2/1/2009 10:22:40 AMMark
Thanks for the info Mark!
If the reactors check okay. I assume I can leave them in the can and move on to the caps.
:Mark: My Westinghouse WR-8 uses the same chassis as the Radiola 82 and the filter reactor is simply a choke. Resistance values are given on the schematic so that you can check it with a meter to see if it is shorted or open. The filter reactor along with the filter caps helps to smooth out the DC power and reduce hum. Mark from Kalamazoo
2/1/2009 1:55:17 PMRene
If the reactor/filter chokes are bad, then there's a fix for that. As it turns out, Bill Werzner from the Houston Vintage Radio Association presented a work-around for the very same set this past Friday. I can email a scan of his mod if you need it.
2/2/2009 5:53:05 AMMark
Thanks Rene!
That would be great. Is there a way I can give you my email address
personally of do I post it on the forum?
Mark
:If the reactor/filter chokes are bad, then there's a fix for that. As it turns out, Bill Werzner from the Houston Vintage Radio Association presented a work-around for the very same set this past Friday. I can email a scan of his mod if you need it.
2/2/2009 9:18:51 AMRene
You should be able to post your addie here...maybe replace the "@" with "at" so your email address isn't picked up by those programs that scan the internet for email addresses.
:Thanks Rene!
:That would be great. Is there a way I can give you my email address
:personally of do I post it on the forum?
:Mark
::If the reactor/filter chokes are bad, then there's a fix for that. As it turns out, Bill Werzner from the Houston Vintage Radio Association presented a work-around for the very same set this past Friday. I can email a scan of his mod if you need it.
2/2/2009 10:10:26 AMMark
Thanks!
mwilliams at post-dispatch.com
Mark
:You should be able to post your addie here...maybe replace the "@" with "at" so your email address isn't picked up by those programs that scan the internet for email addresses.
::Thanks Rene!
::That would be great. Is there a way I can give you my email address
::personally of do I post it on the forum?
::Mark
:::If the reactor/filter chokes are bad, then there's a fix for that. As it turns out, Bill Werzner from the Houston Vintage Radio Association presented a work-around for the very same set this past Friday. I can email a scan of his mod if you need it.
2/2/2009 12:25:35 PMRene
OK, I should be able to send the scan tonight.
:Thanks!
:mwilliams at post-dispatch.com
:Mark
::You should be able to post your addie here...maybe replace the "@" with "at" so your email address isn't picked up by those programs that scan the internet for email addresses.
:::Thanks Rene!
:::That would be great. Is there a way I can give you my email address
:::personally of do I post it on the forum?
:::Mark
::::If the reactor/filter chokes are bad, then there's a fix for that. As it turns out, Bill Werzner from the Houston Vintage Radio Association presented a work-around for the very same set this past Friday. I can email a scan of his mod if you need it.
2/3/2009 6:24:43 AMMark
Hi Rene!
Thanks for the scan!! I'll keep you posted on the outcome.
Mark
:OK, I should be able to send the scan tonight.
::Thanks!
::mwilliams at post-dispatch.com
::Mark
:::You should be able to post your addie here...maybe replace the "@" with "at" so your email address isn't picked up by those programs that scan the internet for email addresses.
::::Thanks Rene!
::::That would be great. Is there a way I can give you my email address
::::personally of do I post it on the forum?
::::Mark
:::::If the reactor/filter chokes are bad, then there's a fix for that. As it turns out, Bill Werzner from the Houston Vintage Radio Association presented a work-around for the very same set this past Friday. I can email a scan of his mod if you need it.
2/2/2009 2:30:32 PMPete Crosby
Mark, There is two nice articles for the
Radiola 18 on this site. Under References.
http://www.nostalgiaair.org/References/Articles/Singles/Radiola18-2.htm
