Thanks, Dave
Your original 51 Mercury radio WILL work either negative or positive ground; UNLESS you have installed a solid state vibrator. These are very polarity sensitive and will burn out in an instance if powered wrong. If you are using a solid state vibrator, all you need to do is get one made for negative ground and you are good to go.
If you are using a mechanical vibrator (hums when working), the radio does not care what the polarity is. The voltage reducer will get very hot, be sure to mount it away from anything that can burn.
Another solution is to have someone convert the radio to operate on 12 volts (again, with a mechanical vibrator, polarity does not matter). I have converted literally dozens of 6 volt radios to 12 volt.
Meade
::Helo,
::I have converted my 1951 Merc to 12-volt negative ground and it works fine. I'm now ready to look at the radio. If I install a 12-volt to 6-volt 15-amp reducer regulator in the radio power circuit to the radio, will the original 6-volt (positive ground) tube radio work. I have read info that some Ford/Mercury radios that were originally positive ground would not work with 6-volt negative ground. Any help would be appreciated.
:Thanks, Dave
:Your original 51 Mercury radio WILL work either negative or positive ground; UNLESS you have installed a solid state vibrator. These are very polarity sensitive and will burn out in an instance if powered wrong. If you are using a solid state vibrator, all you need to do is get one made for negative ground and you are good to go.
: If you are using a mechanical vibrator (hums when working), the radio does not care what the polarity is. The voltage reducer will get very hot, be sure to mount it away from anything that can burn.
:Another solution is to have someone convert the radio to operate on 12 volts (again, with a mechanical vibrator, polarity does not matter). I have converted literally dozens of 6 volt radios to 12 volt.
:Meade
Meade:
The rectifier would give you the proper polarity, but I would look for polarized caps in the 6 Volt wiring, they would have to be reversed. I don't think that many radios had them, but some did, as I recall.
Lewis,
I would be interested in knowing about any vibrator powered radios that had polarized capacitors (electrolytics) in the 6 or 12 volt wiring. Possibly European auto radios? There are several vibrator powered radios that are polarity sensitive, notably the Mopar Town & Country sets with a search motor. If polarity is reversed on these, the search motor will run backwards and the tuning mechanism will jam. However, the radio proper will still work either way--just don't operate the search function!
Meade
meade:
Then I guess we would have to make a more general statement, such as: "While the rectifier will give you the right polarity for B+, there still may be polarity sensitive components in the 6/12 Volt circuity that would have to be reversed in order to work properly."
