::That is a great radio. It sure is worth getting it going again. You can download the schematic here. Don't connect your antenna to your pipes, as that is grounding it out. Just a long wire should do. If you are getting noise when turning the volume control, that's a good thing alright. The transformer being replaced I would hope someone knew what they were doing. As a start for now, if you can have the tubes tested. Then with the aid of the schematic, check for open coils such as the antenna coil ect. I take it you are new at this, So keep posting. I am sure with the help of all the other radio guys here, you will have it singing again.
Thanks for the info Warren, I really appreciate it. I know enough just to be dangerous if you know what I mean, but I think with the help from you guys I can get through the repairs. I did in fact download the schematics which will definitely help, take care...
Jon
