:Does anyone know if I can use four 10uf 450V electrolytics to get 10 uf 900v (500V min)? I want a higher voltage rating in case the field coil ever opens. The 6T2 Plays again but having to use a 650VAC CT Xfmr instead of a 630 CT, At Rect cathode,I get more than 10VDC extra than expected 325V it's 340V with circuit loads, and over 450V Unloaded with 10uf on it.
Ray, Since I said a 650 CT would be ok I need just to be a little clearer on your voltage readings. Voltage reading on the cathode is DC not AC from the power transformer secondary.
The schematic readings of 315 VAC on the plates of the rectifier tube will be higher, how much? The 340 Volts DC reading on the cathode of the rectifier will be slightly higher, how much? The 245 Volts DC on the 6F6 plate will be slightly higher, how much?
Unless you have another problem your replacement power transformer is ok in my view.
Bill
Ray, 340 VDC on pin 8 of rectifier sounds good to me. But 315 VDC after the field coil? Not good. Check resistance of the field coil. Low resistance means much higher output voltage. So you should measure the voltage on the plate and screen grid of the 6F6 too. Test your 5V4. I don't believe a solid state replacement will take care of your problem. I would stay with a tube. You can buy solid state replacements off Ebay and other places.
Bill
Proceed as you wish Ray. I'm not getting you anywhere. By-the-way you don't disconnect the field coil from the circuit to take voltage reading. You are fortunate in that you had a fuse.
Bill
