What am I missing?
:I wonder why the 2a6 is a sub for the 55
:and the 75 seems to be the same as an 85 yet the tube substitution guides don't say so.
:What am I missing?
Somebody leave the door to the nursery open again?
:What am I missing?
Not sure what "Parallel connected circuits" refers to exactly in this case.
This Gilfillan radio uses a 2A6 just as the print calls for.. but the socket actually says 55 printed on it... and as I said either works.
From what I have found out from others now... the 55 and 2A6 ARE swappable but the 2A6 has higher gain.
.. and the same goes for the 75/85 situation.... the 75 has higher gain.
The 55 is rated at 1 amp for the heater whilst the 2A6 is 0.8 amps. For series connected heaters the extra 200mA might cause problems with other tubes?
