::::::If you can pull the cartridge you might find a brand or number on it. Ebay has a vast sellection of sellers and needles. ....Or you could always run it by West Tech Services.
::::::T
:::::According to the SAMS data for the console, Here is the needle you need if installed cartridge is original.
::::: Ebay item number 360107909481. If you search for 2624DS you will find other sellers. Compare and get one. Good price. As said pull the cartridge check for numbers. Ebay cartridge and needle sellers are very helpful.
:::::Bill
::::Here is your needle at
Radio Shack. If you take the 42-2856 number to a store they will order and you pay no shipping. Good deal here.
Shed Radios ::::Bill
:::Bill, I finally did find the sears part number for the needle in of all places it was stuck under the record stack holder???? did not see it until I had the changer out and just happened to see a small tag under it while cleaning the under side, why it was stuck there who can say probably the former owner , does the sams info give the year of the set?
:::Thanks for your info has saved me alot of time searching.
:::Elton
::Elton, that label was most likely done at the factory. Placing a label with needle info somewhere on the changer was one method used. SAMS 965-6 has a date of 6-68. That's close enough for most folks. I don't know the production run. You might find a manufactured date stamped somewhere on your set.
::Bill
:Thanks Bill, Also If I could indulge you , I replaced the NPN output that was shorted with a general purpose trasistor I had lying around since the silvertone numbers don't match to any of the cross refernces books I have, the chassis sticker says need to replace in a matched pair which I did not do , I do notice the channel is a little fuzzy at low volume is it because I did not replace both ? what number transistors does the sams call for on the outputs?
:Thanks for your help
:Elton
Elton you should always replace both output transistors if one tests bad. Sears number being 86-313-2. Replacement GE-13MP and RCA SK3013. X-ref for SK3013 is ECG 121MP. Some I've heard would replace all four output transistors. Others may speak to this?
Bill
