:You can just use the sink with hot water and dish soap and the spray hose too.
:Cloth wire will not be effected by water... and labels can be lacquered over first or removed.
http://jmpalm.home.mindspring.com/
Murphys oil soap in a spray bottle 25/75 mix in warm water will remove cigarette smoke smell. rinse, and pat dry.
:Check this link. Says he can make it for $18 even if it's not listed in current inventory.
:http://jmpalm.home.mindspring.com/
:Murphys oil soap in a spray bottle 25/75 mix in warm water will remove cigarette smoke smell. rinse, and pat dry.
Regarding chassis cleaning, I wash gently in a sink of warm soapy water, and then rinse in warm clean water. If you are really gentle, the labels shouldn't come off. Don't scrub around the labels. You could wax soak them, which would preserve them well without making them brittle. However, wax might darken the label.
Things you should not soak: IF transformers, transformers in general, condensers in a non-wax permeated cardboard tube (unless the condenser has been re-stuffed with a metalized film unit), and anything else that looks like it will retain water for a long time. Small open coils and such can be soaked. To dry, first make sure that the rinse water is nice and warm, or possibly hot. Then place on top of a radiator or in the oven. First thoroughly pre-heat the oven to about 150 to 200 degrees. Then turn it off and put your chassis inside. With some ovens you can leave them running at the lowest possible temperature with fine results. With others, damage will be done to the radio. Be sure that all meltable plastic items are removed before placing in an oven. Starting at 150 to 200 degrees with the oven shut off afterward shouldn't be harmful to rubber wiring. Repeat the cycle after an hour if everything isn't dry yet.
If a transformer is big, with lots of wires, or is mounted in such a way that you don't feel like removing it, you can turn the chassis in such a way that water doesn't contact the transformer. Pull the chassis out to scrub. Then re-soak in such a way that water doesn't enter the transformer. If small amounts of water splash onto the transformer, it will most likely dry without troubles. Just don't soak it. In instances where the transformer handles high voltages, and might arc, give the chassis at least a day of drying time in one of the warm areas suggested above before powering it up.
You can also try, wetting some paper towels with pure vanilla extract and pack them under the chassis for a day or two. Vanilla extract is a great odor eliminator. Don’t use the imitation.
