One thing to keep in mind is that if the tire isn't vulcanized to the metal wheel, but seems to fit in a groove, you might consider replacing it with an O ring of appropriate size. I did this to a 1940s bakelite Admiral (with the reverse painted tone arm and stress gauge pick-up), and it works well.
:Hi Ray,Are your idler wheels completely rotted and cracked or have they just gotten hard and glazed or maybe have a dent in them.I just went through this with a Wollensak tape recorder that uses three idlers.I put up an ad for used ones at that other antique radio website with the usual promises and no action.My idlers had dents in them from sitting so long.I took them out and chucked them into a drill press.I used a medium grit stone and ground the dents out.Removes the old rubber and leaves a nice finish.Because they are idlers,the small reduction in size makes no difference in speed.There are quite a few places that have them N.O.S.,but I wasn't about to pay $40-$50 a piece.Do a Google on "phono idler wheels" and you will find them,just be sitting down when you check prices.These places also usually have rebuilding services for slightly less money.
:I have a need for either rep idler wheels for a 1954 Admiral and a 1940s GE turntables, or a small supply of rubber stock that has the right thickness and can be cut to shape. Also where can I find neoprene rubber tubing or really small and wide drive belts for roler couplings on the Admiral?
Ray: I restore primarily radios but also do an occasional record player. When I need an idler wheel I do not have I carefully measure the diameter and the shaft hole and make one from brass on my small metal lathe leaving a groove to insert an "O" ring for the drive surface. This also makes the drive surface easily replaceable in the future. I realize that you probably do not have a metal lathe but possibly a friend might help you out . . .a machine job shop would not charge too much since it can be machined in about 10 minutes on a manual non CNC lathe.
