Philco 71: Compensating Condensers
12/27/2000 7:18:03 PMGeoff Estabrooks
What is the best way to test compensating condensers? Can you use a multitester?
12/27/2000 7:35:42 PMNorm Leal
Hi Geoff
If you mean those screw driver adjustable caps, a meter will show if they are shorted. As long as the insulation is there, usually mica, they will be ok.
: What is the best way to test compensating condensers? Can you use a multitester?
