RCA R-74
1/11/2009 12:36:37 AMBrett
I’ve never worked on a radio quite like this one. It’s built I’ll say that. I haven’t seen caps like this before, nor some of the values. I can’t seem to find a decent schematic with good detail and a parts list. Does anyone have any pointers on this radio?
Thanks, Brett
1/11/2009 8:13:53 AMKen Walsh
:Your R-74 cross references to the Canadian chassis RCA R-54 and R-56. Same chassis used on both sides of the border just different numbers. I sent you that schematic and the parts list from the Canadian Redbook. The parts list are listed by RCA stock numbers not as the part numbers given on the schematic but they do give you a good indication of the value and in the case of the resistors the wattage rating.
The R-54 (R-74) schematic was also published in the Canadian RCC manuals. It's on this site and you can find it on the link below. It might be a little clearer than both those two RCA scans.
That link
http://www.nostalgiaair.org/PagesByModel/064/M0030064.pdf
Best Regards
Ken
1/11/2009 12:41:19 PMQuestion about caps.
This unit has what appear to be flat paper caps wrapped in metal on mounting boards. They’re marked 64696 AKL, 64696 AKM, and 64490-2 AKL also, there are long narrow metal wrapped caps (about 3/8”W x 11/2” to 13/4”L in varying thickness) marked X-M, X, CS and one I cant read with out removing. Can I determine the values by these numbers, since I cant read schematics well enough?
Thanks, Brett
1/11/2009 12:56:16 PMBrett
Sorry, my mistake. I can read them all accept the one off the tone control.
Brett
1/11/2009 9:26:38 PMEdd
I can certainly see the difficulty in reading out the value of the 500,000 ohm tone pot, but the C30 tone cap can be read
out as as .02 ufd.
1/11/2009 10:58:34 PMBrett
There is a three digit mmfds I cant make out. (xxxmmfds)http://www.nostalgiaair.org/Resources/712/M0015712.htm
Riders Volume 3 - RCA 3-34
Thanks, Brett
1/12/2009 12:18:36 AMEdd
out as as .02 ufd.
O.K. then, there is additionally the fixed, in circuit capacitor C29 that is initially holding back the very highest treble frequencies.
Its value is 745 mmf-----pf's.
Now, in these times, one would use a common dipped silver mica capacitor of a 750 pf rating for its replacement. The same type for the other ones you found also, with you not mentioning their locations, but I am familiar with that ooold style of crimped metal casing construction.
1/12/2009 10:21:41 PMBrett - one more thing
Good, I read it at 745mmfd also but wasn't sure (should these be replaced?). Question 2. In the cap can of 13 caps there are (3) 10uf caps and (1)7uf. I can't locate a 6.8uf and another 10uf would be out of the 20% spec. Also, what type of cap should I use for this Application. There's a big price difference between caps.
1/12/2009 11:48:39 PMLewis Linson
:Good, I read it at 745mmfd also but wasn't sure (should these be replaced?). Question 2. In the cap can of 13 caps there are (3) 10uf caps and (1)7uf. I can't locate a 6.8uf and another 10uf would be out of the 20% spec. Also, what type of cap should I use for this Application. There's a big price difference between caps.
Brett:
I might get some disagreement on this, but in my opinion (humble or not) there is such a wide tolerance on these electrolytic caps, and so much "slop" in building them, that most anything remotely close to the original capacity should work. At least, you are not going to hurt anything, and you can always put something proper in its place if you are not happy with the results of an experement.
1/12/2009 11:54:04 PMMarv Nuce
Lewis,
A lot of electrolytics are rated +20/-80% too, so your thoughts are on target.
::Good, I read it at 745mmfd also but wasn't sure (should these be replaced?). Question 2. In the cap can of 13 caps there are (3) 10uf caps and (1)7uf. I can't locate a 6.8uf and another 10uf would be out of the 20% spec. Also, what type of cap should I use for this Application. There's a big price difference between caps.
:Brett:
:I might get some disagreement on this, but in my opinion (humble or not) there is such a wide tolerance on these electrolytic caps, and so much "slop" in building them, that most anything remotely close to the original capacity should work. At least, you are not going to hurt anything, and you can always put something proper in its place if you are not happy with the results of an experement.
:Lewis
1/13/2009 12:07:09 PMEdd
Methinks that the server possibly corrupted the figures or your having an errant synapse enacted a dyslexic typing transversal of +/-‘us-es-es.. . . .lol.
A lot of electrolytics are rated -20/+ 80% too, so your thoughts are on target ..
(I've even seen +100 thru +200% specs. . . .ergo. . . . seems like rolling capacitors and computing electrolyte action is STILL not an exacting science.)
:Lewis,
:A lot of electrolytics are rated +20/-80% too, so your thoughts are on target.
:marv
:::Good, I read it at 745mmfd also but wasn't sure (should these be replaced?). Question 2. In the cap can of 13 caps there are (3) 10uf caps and (1)7uf. I can't locate a 6.8uf and another 10uf would be out of the 20% spec. Also, what type of cap should I use for this Application. There's a big price difference between caps.
::Brett:
::I might get some disagreement on this, but in my opinion (humble or not) there is such a wide tolerance on these electrolytic caps, and so much "slop" in building them, that most anything remotely close to the original capacity should work. At least, you are not going to hurt anything, and you can always put something proper in its place if you are not happy with the results of an experement.
::Lewis
1/13/2009 11:11:02 PMMarv Nuce
Dr.Edd,
So what is the prognosis for my severe case of dyslexia (I think) at 70 yrs? Am I hopeless, or is there a cure for my errors of transposition. Can I be rehabilitated and remain a contributing member of the NA Forum? Reminds me of a joke of yesteryear concerning a period (.) I stand corrected, but remember seeing that particular tolerance quote on several old can style capacitors.
:Methinks that the server possibly corrupted the figures or your having an errant synapse enacted a dyslexic typing transversal of +/-‘us-es-es.. . . .lol.
: A lot of electrolytics are rated +20/-80% too, so your thoughts are on target.
:A lot of electrolytics are rated -20/+ 80% too, so your thoughts are on target ..
:(I've even seen +100 thru +200% specs. . . .ergo. . . . seems like rolling capacitors and computing electrolyte action is STILL not an exacting science.)
::Lewis,
::A lot of electrolytics are rated +20/-80% too, so your thoughts are on target.
::marv
::::Good, I read it at 745mmfd also but wasn't sure (should these be replaced?). Question 2. In the cap can of 13 caps there are (3) 10uf caps and (1)7uf. I can't locate a 6.8uf and another 10uf would be out of the 20% spec. Also, what type of cap should I use for this Application. There's a big price difference between caps.
:::Brett:
:::I might get some disagreement on this, but in my opinion (humble or not) there is such a wide tolerance on these electrolytic caps, and so much "slop" in building them, that most anything remotely close to the original capacity should work. At least, you are not going to hurt anything, and you can always put something proper in its place if you are not happy with the results of an experement.
:::Lewis
