Identification Help
1/10/2009 3:20:36 PMByron Hukee
I need assistance with identification of an old vintage tube AM radio. I estimate it is from the 1930s, but am not sure. I can send photos to whomever is willing to assist.
1/10/2009 3:43:00 PMJohnny
:Hi Byron,
A make and model number would be helpful in identification. Also if you could supply a tube line-up, what tubes are in the radio, that would be helpful.
Johnny
:I need assistance with identification of an old vintage tube AM radio. I estimate it is from the 1930s, but am not sure. I can send photos to whomever is willing to assist.
1/10/2009 4:33:21 PMByron Hukee
::Hi Byron,
:A make and model number would be helpful in identification. Also if you could supply a tube line-up, what tubes are in the radio, that would be helpful.
:Johnny
::I need assistance with identification of an old vintage tube AM radio. I estimate it is from the 1930s, but am not sure. I can send photos to whomever is willing to assist.
1/10/2009 4:39:12 PMByron Hukee
:::Hi Byron,
::A make and model number would be helpful in identification. Also if you could supply a tube line-up, what tubes are in the radio, that would be helpful.
::Johnny
:::There is no make nor model number visible. There is no back to the wooden case, so I suspect that information may have been there. There is a metal plate on the back of the chassis with the following info:
Licensed under patents of
Radio Corporation of America
General Electric Company
Westinghouse Electric & Mfg Co.
and associated companies and under
Hazeltine & Latour patents by
Hazeltine Corporation
to extent shown by notice within
Serial No. DX 26077
I can send pictures if you'd like
1/10/2009 5:56:14 PMJohnny
::::Hi Byron,
:::A make and model number would be helpful in identification. Also if you could supply a tube line-up, what tubes are in the radio, that would be helpful.
:::Johnny
::::There is no make nor model number visible. There is no back to the wooden case, so I suspect that information may have been there. There is a metal plate on the back of the chassis with the following info:
:Licensed under patents of
:Radio Corporation of America
:General Electric Company
:Westinghouse Electric & Mfg Co.
:and associated companies and under
:Hazeltine & Latour patents by
:Hazeltine Corporation
:to extent shown by notice within
:Serial No. DX 26077
:I can send pictures if you'd like
:What are the tube numbers that are in it?
1/11/2009 5:44:12 PMByron Hukee
:::::Hi Byron,
::::A make and model number would be helpful in identification. Also if you could supply a tube line-up, what tubes are in the radio, that would be helpful.
::::Johnny
:::::There is no make nor model number visible. There is no back to the wooden case, so I suspect that information may have been there. There is a metal plate on the back of the chassis with the following info:
::Licensed under patents of
::Radio Corporation of America
::General Electric Company
::Westinghouse Electric & Mfg Co.
::and associated companies and under
::Hazeltine & Latour patents by
::Hazeltine Corporation
::to extent shown by notice within
::Serial No. DX 26077
::I can send pictures if you'd like
::What are the tube numbers that are in it?
The tube numbers are 25Z5, 25L6, 6D6, and 6D4. The last two have terminal caps on top.
1/11/2009 6:06:50 PMWarren
::::::Hi Byron,
:::::A make and model number would be helpful in identification. Also if you could supply a tube
:::::Johnny
::::::There is no make nor model number visible. There is no back to the wooden case, so I suspect that information may have been there. There is a metal plate on the back of the chassis with the following info:
:::Licensed under patents of
:::Radio Corporation of America
:::General Electric Company
:::Westinghouse Electric & Mfg Co.
:::and associated companies and under
:::Hazeltine & Latour patents by
:::Hazeltine Corporation
:::to extent shown by notice within
:::Serial No. DX 26077
:::I can send pictures if you'd like
:::What are the tube numbers that are in it?
:The tube numbers are 25Z5, 25L6, 6D6, and 6D4. The last two have terminal caps on top.
WOW .. 6D6 is a six pin
6D4 is a seven pin Thyratron
25Z5 a six pin
25L6 an eight pin
Good one. Don't even add up too .. I have no clue.
1/11/2009 6:14:21 PMJohnny
::::::Hi Byron,
:::::A make and model number would be helpful in identification. Also if you could supply a tube line-up, what tubes are in the radio, that would be helpful.
:::::Johnny
:Tell Warren to read the rest of the story and he may find that his requested info has already been given. As far as for me I have exhausted all my resources and cannot come up with the info you need. There are others here more experienced then I and they may jump in and be of some help. Sorry! Johnny
1/11/2009 6:45:43 PMWarren ( ?? )
:::::::Hi Byron,
::::::A make and model number would be helpful in identification. Also if you could supply a tube line-up, what tubes are in the radio, that would be helpful.
::::::Johnny
:::::::There is no make nor model number visible. There is no back to the wooden case, so I suspect that information may have been there. There is a metal plate on the back of the chassis with the following info:
::::Licensed under patents of
::::Radio Corporation of America
::::General Electric Company
::::Westinghouse Electric & Mfg Co.
::::and associated companies and under
::::Hazeltine & Latour patents by
::::Hazeltine Corporation
::::to extent shown by notice within
::::Serial No. DX 26077
::::I can send pictures if you'd like
::::What are the tube numbers that are in it?
::The tube numbers are 25Z5, 25L6, 6D6, and 6D4. The last two have terminal caps on top.
::Tell Warren to read the rest of the story and he may find that his requested info has already been given. As far as for me I have exhausted all my resources and cannot come up with the info you need. There are others here more experienced then I and they may jump in and be of some help. Sorry! Johnny
May have been a misreading in the posting order, But Byron did give the tube numbers. I posted the WOW, and about the tube pins. The mystery continues. <> Warren<>
1/12/2009 10:34:01 AMByron Hukee
::::::::Hi Byron,
:::::::A make and model number would be helpful in identification. Also if you could supply a tube line-up, what tubes are in the radio, that would be helpful.
:::::::Johnny
::::::::There is no make nor model number visible. There is no back to the wooden case, so I suspect that information may have been there. There is a metal plate on the back of the chassis with the following info:
:::::Licensed under patents of
:::::Radio Corporation of America
:::::General Electric Company
:::::Westinghouse Electric & Mfg Co.
:::::and associated companies and under
:::::Hazeltine & Latour patents by
:::::Hazeltine Corporation
:::::to extent shown by notice within
:::::Serial No. DX 26077
:::::I can send pictures if you'd like
:::::What are the tube numbers that are in it?
:::The tube numbers are 25Z5, 25L6, 6D6, and 6D4. The last two have terminal caps on top.
:::Tell Warren to read the rest of the story and he may find that his requested info has already been given. As far as for me I have exhausted all my resources and cannot come up with the info you need. There are others here more experienced then I and they may jump in and be of some help. Sorry! Johnny
: May have been a misreading in the posting order, But Byron did give the tube numbers. I posted the WOW, and about the tube pins. The mystery continues. <> Warren<>
About the tubes. The first two were determined with markings on the tubes. There were no markings on the last two (6D6 and 6D4) but there was writing next to the socket in pencil with those marks on it. I should say that the writing was also present for the first two, and it was correct.<>Byron<>
1/12/2009 3:12:00 PMEdd
Sir Byron:
Oh. . . .WOW. . . . I think that you have now given us our dose of the start of an Ellery Queens mystery.
For my part. . . .I’ve got some questions. . .let’s see if you can supply the answers.. . .a la Radio Shaque
I am assuming that you have got a tube present in every tube socket in the set, and that there are no empty sockets. . .and those were the numbers that you have supplied us ?
Are there any shared common brands marked on more than 1 of the tubes. . . if still legible. . .and if it is being of a radio manufacturer label ?
Now if this is a bare bones receiver and if only using a mere 4 tubes, THAT is a bare bones receiver for a Super heterodyne. We can see that some of your given tube type numbers readily tie in to some of the required functions of making up a radio receiver.
Initially, there is the 25Z5 which would be the power tube which creates the DC voltage needed for the set.
Then there is the 25L6 tube which would be the final AF audio output amp which would be bringing up the sets audio to a speaker driving power level.
Now that leaves the 6D6, which would typically be an IF or RF amp function on a set with a few more tubes in its lineup. . . .BUT. . . . in this starved circuitry, it could be its sole RF front end entity, in the respect that it is serving as its mixer.
Should that be the case, with the set only using 4 tubes, then it would be necessary to allay the use of an IF tube entirely and dump that 6D6 mixer directly into a single I.F. transformer with its secondary then being detected with the diode of a tube and fed to a stage of audio amplification to then to drive that 25L6 AF output tube.
Setting up the next question. . .is there only one I.F. transformer can in the set ?
Soooooo. . .it seems to now be the necessity of solving the identity of that fourth tube in the lineup that you have given. . . . .and we certainly don’t see the use of any 6D4 thyratrons being used in an “Un American 4 receiver”, PLUS a 6D4 is in a 7 pin mini envelope !
Now, with your mentioning there being “caps” on both of the last listed tubes, that does tie in with the 6D6’s use, exactly, with it having a top mounted grid cap.
Now what I would really expect for the final tube with the top “cap”, would for it to be a 75, or in that family, such that its diode section performs the RF to audio detection function and then, that developed low level audio is passed on to the triode section of that same tube, for bringing it on up to that 25L6’s required driving level.
Another question from my series, would be for you to find the 25L6 audio output tube and realize that the AF input to that tube is going to be coupled into it from its previous audio stage via an audio coupling capacitor and the other end of that cap should be routed over to the wiring and circuitry associative to our mystery tube.
Just as a circuit aid, I placed a thumbnail at the bottom for clarification, it encompasses the utilization of the two tubes mentioned and you see that the capacitor in query is C1 with it going the red arrow route over to thee left and connecting to the plate of the 1st audio tube for acquiring its audio signal.
Now you want to trace down your “RED ”wiring and see what pin number of the tube socket that it is routed to and makes its termination. Then we figure what tube it might be.
Last consideration will be your forwarding the info on the tube socket ID of the mystery tube, be it in the octal category as the 25Z5-25L6 are, or is it of the large 7 pin sizing, such as the 6D6 is.
Lastly, in case the mystery tube is not the 75 or its equivalency in an octal tube, there is the final consideration of it using a common triode in that position and of the utilization of grid detection for the RF detection aspect and conventionally , that would be notable via the utilization of a higher resistive value used for its cathode resistor.
ZUJ’ing for your feedback. . . ..
Applicable Thumbnail:
1/12/2009 6:36:41 PMByron Hukee
Wow, I am a former fighter pilot and I though we used a lot of "jargon!" I have no idea what a hetrodyne and what makes some of them super so Edd's post went way over my head. But here is a link to some photos with some captions that may help solve the mystery. One error I made when sending tube IDs was that there is no 6D4. The two tubes with the cap terminals are 6D6 and 6C6. Go to http://gallery.me.com/bhukee/100067 to see photos that may help solve the mystery.
Byron H
1/12/2009 9:51:37 PMEdd
Well with your pics referencing, one now sees that this radios Super- Hot –Rodent-Dyne design category, will now have to be downgraded down to a mere TRF unit, with you now mentioning that 6C6 as being the mystery tube.
* * *Fly-boy comment
That wooden cabinetry sort of reminds me of a Sonora. .or Fada . .. excluding the knob set, but others that may have seen these old units will have to confirm that being a possibility,
If one consults a Sonora, incorporating the A11 chassis, it seems like that circuitry design would assimilate close enough to make troubleshooting analysis possible using that info.
Now, considering by the photos that your frontal RF coil / transformer is still intact up at the front chassis corner nearside of the 2 section tuning condenser. . .BUT . . .the gaping hole between the 6D6 and 6C6 implies that the RF / detector transformer is cannibalized / missing from the set.
I also see the sets intact power supply filter condensers as being tubular cardboard cased units, downstairs.
In looking at the chassis hole in the frontal area of the 6C6, I’m wondering if an earlier set was using this same chassis pan and might have used a metal wet electrolytic filter capacitor mounted in that area.
The use of several common Arcturus branded tubes doesn’t seem to help in identifying a set maker tie in.
That’s about all that I can see from the data so far; maybe others can chip in now.
Flyboy tie in. . .possible commonality:
*** And now, would that itinerary consist of a past history of:
F86’s in . . . Yalu “excursions”
Foxy- 105 “Thuds” in Vietnam
and a final hurrah with Falcons. . .
Yet, with that all time fear in the back of ones head of reduction in armament to the degree that one is dependant upon ones
wing men, should one not be able to “Vulcanize” anymore, on any encountered bogey on the way home.
F16thunderjockey ->-
1/12/2009 11:10:38 PMBill VA
:Well with your pics referencing, one now sees that this radios Super- Hot –Rodent-Dyne design category, will now have to be downgraded down to a mere TRF unit, with you now mentioning that 6C6 as being the mystery tube.
:* * *Fly-boy comment
:That wooden cabinetry sort of reminds me of a Sonora. .or Fada . .. excluding the knob set, but others that may have seen these old units will have to confirm that being a possibility,
:If one consults a Sonora, incorporating the A11 chassis, it seems like that circuitry design would assimilate close enough to make troubleshooting analysis possible using that info.
:Now, considering by the photos that your frontal RF coil / transformer is still intact up at the front chassis corner nearside of the 2 section tuning condenser. . .BUT . . .the gaping hole between the 6D6 and 6C6 implies that the RF / detector transformer is cannibalized / missing from the set.
:I also see the sets intact power supply filter condensers as being tubular cardboard cased units, downstairs.
:In looking at the chassis hole in the frontal area of the 6C6, I’m wondering if an earlier set was using this same chassis pan and might have used a metal wet electrolytic filter capacitor mounted in that area.
:The use of several common Arcturus branded tubes doesn’t seem to help in identifying a set maker tie in.
:That’s about all that I can see from the data so far; maybe others can chip in now.
:Flyboy tie in. . .possible commonality:
:*** And now, would that itinerary consist of a past history of:
:F86’s in . . . Yalu “excursions”
:Foxy- 105 “Thuds” in Vietnam
:and a final hurrah with Falcons. . .
:Yet, with that all time fear in the back of ones head of reduction in armament to the degree that one is dependant upon ones
:wing men, should one not be able to “Vulcanize” anymore, on any encountered bogey on the way home.
:F16thunderjockey ->-
The dial pointer sort of reminds me of a Fada...maybe model 5F50? If the speaker has a stamped number that may help. Seems I see something on it.
Bill
