Hi David,
I don't know anything about your set but it uses European valves (tubes). If your not familiar with them here are the American equivalent numbers: ECH81 ia triode heptode frequency converter, 6AJ8. The EF80 is a sharp cutoff FR pentode, 6BX6. The EZ81 is a full wave vacuum rectifier, 6CA4. The oa2 is 150 volt,5 to30 mA voltage regulator. You might already know this information but if not it may help you find your way around the set. If I can be of any further help, please ask. Don. PS it's an interesting valve lineup, using two converters (one for a BFO perhaps?) and a single sharp cutoff pentode.
: Hi David,
: I don't know anything about your set but it uses European valves (tubes). If your not familiar with them here are the American equivalent numbers: ECH81 ia triode heptode frequency converter, 6AJ8. The EF80 is a sharp cutoff FR pentode, 6BX6. The EZ81 is a full wave vacuum rectifier, 6CA4. The oa2 is 150 volt,5 to30 mA voltage regulator. You might already know this information but if not it may help you find your way around the set. If I can be of any further help, please ask. Don. PS it's an interesting valve lineup, using two converters (one for a BFO perhaps?) and a single sharp cutoff pentode.
