airline (mont ward) wg-2314a please help!!
1/5/2009 12:15:10 AMdaniel adams
i just bought this radio and cant find any info on it PERIOD.i need allighnment procedure and schematic.also any other info would be greatly appreciated,thank you in advance.please feel free to call me or shoot me an email daniel adams 334 701 8897 or dladams76@hotmail.com
1/5/2009 2:11:05 AMWarren
:i just bought this radio and cant find any info on it PERIOD.i need allighnment procedure and schematic.also any other info would be greatly appreciated,thank you in advance.please feel free to call me or shoot me an email daniel adams 334 701 8897 or dladams76@hotmail.com
About what year is it ? If it's in the 30's it very well could be made by Belmont. Give a tube line up on your next post.
1/5/2009 6:11:49 AMCarl T
::i just bought this radio and cant find any info on it PERIOD.i need allighnment procedure and schematic.also any other info would be greatly appreciated,thank you in advance.please feel free to call me or shoot me an email daniel adams 334 701 8897 or dladams76@hotmail.com
:About what year is it ? If it's in the 30's it very well could be made by Belmont. Give a tube line up on your next post.
The schematic is in Sam's 677-6.
WG = Wells Gardner.
Carl T
1/5/2009 7:36:36 PMdaniel adams
:::i just bought this radio and cant find any info on it PERIOD.i need allighnment procedure and schematic.also any other info would be greatly appreciated,thank you in advance.please feel free to call me or shoot me an email daniel adams 334 701 8897 or dladams76@hotmail.com
::About what year is it ? If it's in the 30's it very well could be made by Belmont. Give a tube line up on your next post.
:The schematic is in Sam's 677-6.
:WG = Wells Gardner.
:Carl T
i dont know what year it is.im guessing in the 60s.it is stereo and says high fidelity.it is a console type with phono.still cant get any info on it
1/5/2009 8:06:39 PMBill VA
::::i just bought this radio and cant find any info on it PERIOD.i need allighnment procedure and schematic.also any other info would be greatly appreciated,thank you in advance.please feel free to call me or shoot me an email daniel adams 334 701 8897 or dladams76@hotmail.com
:::About what year is it ? If it's in the 30's it very well could be made by Belmont. Give a tube line up on your next post.
::The schematic is in Sam's 677-6.
::WG = Wells Gardner.
::Carl T
:i dont know what year it is.im guessing in the 60s.it is stereo and says high fidelity.it is a console type with phono.still cant get any info on it
SAMS 677-6 was published Feb 1964. That's close enough to date it. You could look for a mfr'd date somewhere on the console.
Bill
1/5/2009 8:25:11 PMThomas Dermody
Keep in mind that if it is from the 1960s, it very well might have IF transformers that have permanent silver mica capacitors, which often enough fail. Unless someone tampered with the set, you shouldn't do any aligning yet. First you should start with capacitors. Check for shorts and leakage. If you have money, replace all paper caps, and possibly all electrolytics, though that isn't absolutely necessary. Then check tubes. Check for weak ones and burned out ones. They don't often fail, but they do fail. Check resistors for drifting.
If you aren't getting any reception or it's kinda weak, then, after checking voltages and such, you should check the IF transformers. The silvered mica capacitors they often contain get oxidized. They can either become leaky or open, causing the radio to perform poorly, or not at all. Though it is a bit of a job, these capacitors can be removed, and new reliable units can be soldered to the underside of the IF transformer being repaired.
If the amplifier is working well (try feeding it with a CD player), but the phonograph won't work, the cartridge may need replacing. 1960s phono cartridges are fairly common, and if you can't find one, there's usually another that'll do the trick. It's best, regardless of whether the unit is stereo or mono, to use a stereo cartridge as a replacement. That way you'll be kinder to your stereo records, as they aren't supposed to be played with a monoral cartridge because monoral cartridges often don't have the vertical compliance required by stereo records, though you can technically play stereo records on a mono cartridge, and they usually sound fine, but wear out prematurely.
1/5/2009 11:02:24 PMdaniel adams
:Keep in mind that if it is from the 1960s, it very well might have IF transformers that have permanent silver mica capacitors, which often enough fail. Unless someone tampered with the set, you shouldn't do any aligning yet. First you should start with capacitors. Check for shorts and leakage. If you have money, replace all paper caps, and possibly all electrolytics, though that isn't absolutely necessary. Then check tubes. Check for weak ones and burned out ones. They don't often fail, but they do fail. Check resistors for drifting.
:If you aren't getting any reception or it's kinda weak, then, after checking voltages and such, you should check the IF transformers. The silvered mica capacitors they often contain get oxidized. They can either become leaky or open, causing the radio to perform poorly, or not at all. Though it is a bit of a job, these capacitors can be removed, and new reliable units can be soldered to the underside of the IF transformer being repaired.
:If the amplifier is working well (try feeding it with a CD player), but the phonograph won't work, the cartridge may need replacing. 1960s phono cartridges are fairly common, and if you can't find one, there's usually another that'll do the trick. It's best, regardless of whether the unit is stereo or mono, to use a stereo cartridge as a replacement. That way you'll be kinder to your stereo records, as they aren't supposed to be played with a monoral cartridge because monoral cartridges often don't have the vertical compliance required by stereo records, though you can technically play stereo records on a mono cartridge, and they usually sound fine, but wear out prematurely.
:T.thank you very much guys.i have no electronic experience whatsoever luckily my father has the tube testers and such.to diagnose problems with the old tube types.i appreciate yall responding to my questions.and maybe ill get it sorted out soon.i have been longing for that mellow sound that i grew up with for quite some time and with any luck ill be listening to records before long.i know that one channel is not working.the right i believe.could this be a sign of the permanent capacitors being gone
1/5/2009 11:43:25 PMThomas Dermody
The permanent (though not really) capacitors I was talking about are in the IF transformers in the radio section. Their going bad won't cause one channel to go out. If they go bad, the RADIO will either be quieter or dead all together. One band might not be affected--that is, the AM might work and the FM might be dead, or vice versa.
1/7/2009 6:02:28 PMGit 'er done. . . .. . . . .Larry
3/24/2010 2:32:55 PMMike D.
Is there any way to get a better scan short of paying for one? I have this exact console and would like to be able to see some of the small details in the schematic.
Mike
3/24/2010 6:38:53 PMEdd
Sir Mike Deeeee . . . . . .
WHUT ? . . and I thought that I was being conservative on its sizing, as compared to some others that I have done.
There is hardly anything that I can not make out, except possibly for a decimal place on a very low voltage reading.
Compare that to some of the old Red Riders stufffff that we just have to squint our eyes on verrrry hard and then hope that you are right, since no other documentation was available on that aged equipment . . . this is relatively NEW stuff.
If needing just but a few specifics I CAN go back in and clarify some areas on that schema.
BUT . . . initially try the placing of ye olde meece pointer in the very center of the schema and then right click to then find that you then have the options dialog box showing.
You then raise mouse pointer to highlight the SAVE PICTURE AS and then either right or left click upon your highlighting to then activate the SAVE PICTURE box, in which you go to within the top SAVE IN options of MY PICTURES and highlight it and make your own option of even changing the auto titling at the very bottom option of FILE NAME . . . . of " untitled" .
Then you left click on SAVE and the schema is yours . . . all bitmapped up and saved to permit the most flexibility in viewing / transposing it.
If you will then retrieve it up from your pictures folder, and use a right click on it, to then get a dialog box, then drop down to the central option of OPEN WITH and go to the right, for the then presented options.
There you opt for a right or left click on WINDOWS PICTURE AND FAX VIEWER.
On the, then presented schematic, I find that I can then can then roll forward with the cursor roller to get at least 12 degrees /clicks of further magnification before reaching a clarity "definition wall".
Manipulate across the schematic by using the right side and bottom positioning bars tabs to the side . . via . . . . cursor pointer activation.
:Is there any way to get a better scan short of paying for one? I have this exact console and would like to be able to see some of the small details in the schematic.
:Thanks,
:Mike
::73's de Edd
3/24/2010 7:38:46 PMMike D.
Hi Edd,
I don't mean to be ungrateful. I really appreciate that this is the ONLY site I've been able to find that particular schematic and I appreciate all the work you did in scanning it to an electronic file.
My uncle owned the Wards Airline Radio/phono console that this schematic covers and he passed away recently but said I could have the console. Now I am really interested in restoring some of the components to better working condition. The wood work was really beautiful by the way.
I was just trying to see if there was a way I could beg, plead and generally cajole someone into making a higher bit depth scan that could be emailed to me possibly? If it could also be posted as an alternative download that would be great.
Again, I really appreciate the posting of this file. When I saved it to my drive and tried to print it out there just isn't enough detail to get a good print.
If you need my email address I can provide it off-line if it isn't part of the forum links.
I really dig the old tube gear and have quite a bit of it in various stages of repair (or dis-repair as the case may be) ;^)
I understand if you don't want to hassle with a new scan and I can probably figure out most of it. I just like to have good schematic reprints in my notebook to refer back to.
Thanks so much.
Mike
:Sir Mike Deeeee . . . . . .
:WHUT ? . . and I thought that I was being conservative on its sizing, as compared to some others that I have done.
:There is hardly anything that I can not make out, except possibly for a decimal place on a very low voltage reading.
:Compare that to some of the old Red Riders stufffff that we just have to squint our eyes on verrrry hard and then hope that you are right, since no other documentation was available on that aged equipment . . . this is relatively NEW stuff.
:If needing just but a few specifics I CAN go back in and clarify some areas on that schema.
:BUT . . . initially try the placing of ye olde meece pointer in the very center of the schema and then right click to then find that you then have the options dialog box showing.
:You then raise mouse pointer to highlight the SAVE PICTURE AS and then either right or left click upon your highlighting to then activate the SAVE PICTURE box, in which you go to within the top SAVE IN options of MY PICTURES and highlight it and make your own option of even changing the auto titling at the very bottom option of FILE NAME . . . . of " untitled" .
:Then you left click on SAVE and the schema is yours . . . all bitmapped up and saved to permit the most flexibility in viewing / transposing it.
:If you will then retrieve it up from your pictures folder, and use a right click on it, to then get a dialog box, then drop down to the central option of OPEN WITH and go to the right, for the then presented options.
:There you opt for a right or left click on WINDOWS PICTURE AND FAX VIEWER.
:On the, then presented schematic, I find that I can then can then roll forward with the cursor roller to get at least 12 degrees /clicks of further magnification before reaching a clarity "definition wall".
:Manipulate across the schematic by using the right side and bottom positioning bars tabs to the side . . via . . . . cursor pointer activation.
::Is there any way to get a better scan short of paying for one? I have this exact console and would like to be able to see some of the small details in the schematic.
::Thanks,
::Mike
:::73's de Edd
3/25/2010 5:52:52 PMEdd
Sir . . . . . .Mike Deee
Ahhhhh-Haaaaa . . . . .the PRINTING aspect now fully clarifies your particular situation.
10-20 years ago I always wanted paper schematics . . . now I am just the opposite, only sometimes now will I be taking a Flash drive stored, large bit mapped file down to the Copymax to use one of their oversized sheet printers to make into a large format printout.
Prior to that I was just taking the multiple separate pages that came out with a printout and sitting down with a single edged razor blade to overlay the pages and scotch tape all together.
Sooo . . . what I am sending you is the four pages on that unit, complete with under chassis photos and the additional Stee-row de-multiplex-i-fi-cator .
By the use of marque and dynamic zoom modes on the units Pee Dee Eff formatting, you should then be able to get any select portion sized up for print out.
:Hi Edd,
:I don't mean to be ungrateful. I really appreciate that this is the ONLY site I've been able to find that particular schematic and I appreciate all the work you did in scanning it to an electronic file.
:My uncle owned the Wards Airline Radio/phono console that this schematic covers and he passed away recently but said I could have the console. Now I am really interested in restoring some of the components to better working condition. The wood work was really beautiful by the way.
:I was just trying to see if there was a way I could beg, plead and generally cajole someone into making a higher bit depth scan that could be emailed to me possibly? If it could also be posted as an alternative download that would be great.
:Again, I really appreciate the posting of this file. When I saved it to my drive and tried to print it out there just isn't enough detail to get a good print.
:If you need my email address I can provide it off-line if it isn't part of the forum links.
:I really dig the old tube gear and have quite a bit of it in various stages of repair (or dis-repair as the case may be) ;^)
:I understand if you don't want to hassle with a new scan and I can probably figure out most of it. I just like to have good schematic reprints in my notebook to refer back to.
:Thanks so much.
:Mike
::Sir Mike Deeeee . . . . . .
::WHUT ? . . and I thought that I was being conservative on its sizing, as compared to some others that I have done.
::There is hardly anything that I can not make out, except possibly for a decimal place on a very low voltage reading.
::Compare that to some of the old Red Riders stufffff that we just have to squint our eyes on verrrry hard and then hope that you are right, since no other documentation was available on that aged equipment . . . this is relatively NEW stuff.
::If needing just but a few specifics I CAN go back in and clarify some areas on that schema.
::BUT . . . initially try the placing of ye olde meece pointer in the very center of the schema and then right click to then find that you then have the options dialog box showing.
::You then raise mouse pointer to highlight the SAVE PICTURE AS and then either right or left click upon your highlighting to then activate the SAVE PICTURE box, in which you go to within the top SAVE IN options of MY PICTURES and highlight it and make your own option of even changing the auto titling at the very bottom option of FILE NAME . . . . of " untitled" .
::Then you left click on SAVE and the schema is yours . . . all bitmapped up and saved to permit the most flexibility in viewing / transposing it.
::If you will then retrieve it up from your pictures folder, and use a right click on it, to then get a dialog box, then drop down to the central option of OPEN WITH and go to the right, for the then presented options.
::There you opt for a right or left click on WINDOWS PICTURE AND FAX VIEWER.
::On the, then presented schematic, I find that I can then can then roll forward with the cursor roller to get at least 12 degrees /clicks of further magnification before reaching a clarity "definition wall".
::Manipulate across the schematic by using the right side and bottom positioning bars tabs to the side . . via . . . . cursor pointer activation.
::73's de Edd
:::Is there any way to get a better scan short of paying for one? I have this exact console and would like to be able to see some of the small details in the schematic.
:::Thanks,
:::Mike
::::73's de Edd
5/8/2014 1:08:28 PMAUSTIN
5/8/2014 1:10:25 PMAUSTIN
:: Your set was made by WELLS GARDNER, that's what WG stands for.
5/8/2014 9:06:11 PMCarl T
::: Your set was made by WELLS GARDNER, that's what WG stands for.
Gee, I believe I mentioned that over 5 years ago.
