You are right.
Johnny, if you are going to rewire just put jumopers between pins 3-4, 5-6 and 7-8, then you can use either tube at any time without touching wiring again. PL
Seems that you would have to jumper pin seven to pin two
:: Johnny, if you are going to rewire just put jumopers between pins 3-4, 5-6 and 7-8, then you can use either tube at any time without touching wiring again. PL
Johnny, sorry about that error, and thank you Dan for pointing it out. That was not my idea, I picked it up from some one else and have used it any time I have a unit that uses the 5Y3/4. 7-8 would definately not work well.PL
Anyone have any idea, however, why on earth these two tubes exist? Is there any benefit to one pin-out to another? Why didn't they just stick with one pin-out? Kinda stupid having the same tube with two different base connections. ...Unless it was developed by two different companies. 5Y3 definitely seems to be the more common tube.
Best Regards,
Bill
