:How long have you been working on radios? I don't think you're going to find a 1928 schematic in Sam's...their schematics didn't start until ~1946. You'll need to look in Rider's for something that old.
:Ooops ..My bad ....I meant a Riders schematic...
::How long have you been working on radios? I don't think you're going to find a 1928 schematic in Sam's...their schematics didn't start until ~1946. You'll need to look in Rider's for something that old.
:AHHH....Now that I have your attention...I have been loooking for years ..yes years...on information on my 1928 Montgomery Wards Airline radio. (Yes I posted info about 3 posting ago..sorry for my impatience)
:The radio I have is model A-C Eight Type C. It sits in the "Presidntial" style cabinet. (I have the original 1928 Mongomery Wards catalog that shows this)
:What I am looking for is a schematic. It has a separate power supply and Neutrodyne reciever serial # C-8029. I want to replace old wax paper capacitor block in the pwer supply but do not know all the values or where the wires go to...The reciever has this tube line-up...5 226s 1 227 2 171s and a 280 in the power pack. Power pack is simular in size to what Atwater Kent used. DOES ANYONE HAVE THE SCHEMATIC FOR THIS IN A SAMS BOOK??? Anyway I WOULD GREATLY APPRECIATE ANY HELP!!!
If you the following, you will find the Day-Fan 8 that Rene is suggesting.
http://www.nostalgiaair.org/PagesByModel/945/M0039945.pdf
Doug
::I looked at my Rider's index (vol 1-10) and couldn't find anything from Monty Ward with "AC-8" or "Presidential" in it. I hauled out volume one and couldn't find anything either. After perusing the volume one index I found a set by Day Fan (Day Fan 8). It has the same tube line-up as yours and it's on pg 338. Note that Day Fan may also be under General Motors Radio Corp.
:If you the following, you will find the Day-Fan 8 that Rene is suggesting.
:http://www.nostalgiaair.org/PagesByModel/945/M0039945.pdf
:Doug
There are only two schematics with your tube lineup that has any values for the caps and resistors. One even has 10 terminals out of the power pac. Here they are:
http://www.nostalgiaair.org/PagesByModel/054/M0040054.pdf
http://www.nostalgiaair.org/PagesByModel/659/M0000659.pdf
One is Allied 8/9 AC, and the other is Howard, Green Diamond 8.
You may have already looked at these, but that is all I found with that tube lineup. If these are not close enough, you may be out of luck.
I do have to say I like reading your posts Mr. Berg, cause you sure do get some interesting replies, keep up the "good work". LOL
Doug
:You may have a real oddball set. I have a Bush & Lane Model 2 that to this day I cannot find a schematic for. I ended up drawing my own (had to empty out two big tar boxes) and then I used a variety of Rider schematics that were close to get an idea of component values.
:Yes..I agree...this set has the separate power pack but..thank god only the caps are sealed in wax...Someone has got to know who made this...It was sold by Wards and they were massed produce..Who made the electonic guts for early Wards sets..maybe that will help me..Any Ideas?
::You may have a real oddball set. I have a Bush & Lane Model 2 that to this day I cannot find a schematic for. I ended up drawing my own (had to empty out two big tar boxes) and then I used a variety of Rider schematics that were close to get an idea of component values.
If you're lucky enough to find a 3 digit RMA code somewhere, you should be able to determine the manufacturer IF this code was even in effect when your set was made.
:I have quite a mystery on my hands...If you read previous posting(s) I am having difficulty finding a schematic for my Montgomery Wards ..Airline set..It is a 1928 model AC-8 type C...I am hoping that someone has or knows where to find a schematic for it...The radio has separate power pack (about the same size as Atwater Kent used in their early models like the 37-44 models)..In the power pack the caps sealed in wax..all other electronics are not sealed in tar so I can get to them...ANYWAY..I would like to find a schematic to rplace the caps...The reciever is a neutrodynne reciver with serial number C-8029...ANYONE KNOW WHO MADE THE EARLY AC SETS FOR WARDS...??
::Yes..I agree...this set has the separate power pack but..thank god only the caps are sealed in wax...Someone has got to know who made this...It was sold by Wards and they were massed produce..Who made the electonic guts for early Wards sets..maybe that will help me..Any Ideas?
:::You may have a real oddball set. I have a Bush & Lane Model 2 that to this day I cannot find a schematic for. I ended up drawing my own (had to empty out two big tar boxes) and then I used a variety of Rider schematics that were close to get an idea of component values.
Also, with tuned filters, there often is a small cap around .09 MFD across a filter choke. That is part of the tuned circuit. Do not replace that cap with a larger value cap. A larger value will only bypass hum across the choke. It is best to eliminate this cap all together when other filter caps are increased from their original values. Of course, as was said before, if you wish to maintain the tuned filter circuit, all original values must be used, including the cap across the choke.
I did mention your radio to another old time radio collector. He seems to think it's a Freshman. I did look at some of the schematics, and those seem to be very close to what you have.
Under the Name Apex?
Might be under the model Apex36 or 37 Heading or somewhere around that series?
:Have you checked Riders/U.S Radio And Television
:Under the Name Apex?
:Might be under the model Apex36 or 37 Heading or somewhere around that series?
:Yah I think this is a odd ball..set Apex 36-37 Models are close but my set has one more 71 tube I SEE THE NUMBER 842 stamped on the tuner bracket..that may be something..but i don't know what to make of it...Maybe of Freshman mnfct..hmm will look at that...THANKS FOR ALL YOUR SUGGESTIONS..Since I am not all that of an expert ant electronics..(not yet anyway..lol) I really don't wana dig into the block of caps just yet....I will have to study the leads out of power pack to radio and compare to diagrams like Apex 36 & 37 they seem to be close
::Have you checked Riders/U.S Radio And Television
::Under the Name Apex?
::Might be under the model Apex36 or 37 Heading or somewhere around that series?
:OHH HEY one more thing..the reciever has bright shiny copper plated cans on neutrodyne reciever reciver (serial # C-8029
::Yah I think this is a odd ball..set Apex 36-37 Models are close but my set has one more 71 tube I SEE THE NUMBER 842 stamped on the tuner bracket..that may be something..but i don't know what to make of it...Maybe of Freshman mnfct..hmm will look at that...THANKS FOR ALL YOUR SUGGESTIONS..Since I am not all that of an expert ant electronics..(not yet anyway..lol) I really don't wana dig into the block of caps just yet....I will have to study the leads out of power pack to radio and compare to diagrams like Apex 36 & 37 they seem to be close
:::Have you checked Riders/U.S Radio And Television
:::Under the Name Apex?
:::Might be under the model Apex36 or 37 Heading or somewhere around that series?
: G.Berg, I believe they are Mershon caps. Take a look on Chuck's site (phicorepairbench), he has instructions for stuffing them. PL
::OHH HEY one more thing..the reciever has bright shiny copper plated cans on neutrodyne reciever reciver (serial # C-8029
:::Yah I think this is a odd ball..set Apex 36-37 Models are close but my set has one more 71 tube I SEE THE NUMBER 842 stamped on the tuner bracket..that may be something..but i don't know what to make of it...Maybe of Freshman mnfct..hmm will look at that...THANKS FOR ALL YOUR SUGGESTIONS..Since I am not all that of an expert ant electronics..(not yet anyway..lol) I really don't wana dig into the block of caps just yet....I will have to study the leads out of power pack to radio and compare to diagrams like Apex 36 & 37 they seem to be close
::::Have you checked Riders/U.S Radio And Television
::::Under the Name Apex?
::::Might be under the model Apex36 or 37 Heading or somewhere around that series?
I took a look at a few of those Day Fan schematics. Seems none say what the values are in that capacitor block. However, the Freshman prints do. I think if you follow the Freshman print as to where the capacitors connect to, should be able to come up with working values.
