Might try the schematic for a Packard Bell 8AC:
http://www.nostalgiaair.org/PagesByModel/960/M0012960.pdf
Carl T
or Allied 8/9 AC:
http://www.nostalgiaair.org/PagesByModel/659/M0000659.pdf
:Carl T
::::Hi all..When I starting collecting radios about 15 years ago I came across a 1927-28 Airline radio (model A-C eight type C Presidential style) It is in a stand up phonograph type of case and has huge lift up top... The Electronics still work...but after a few mnts a transformer begins to get very warm (short somewhere) Anyway ..I can not find a schematic for it or technical data. It has a power supply that everything in it is not sealed in tar..So..I want to replace caps and bring up to spec... All the wires
:::that go to cap block ..well I don't know what the values are...ANY HELP?? Or steer me in the righ direction? THANKS!!!
:::OOOPS also the reciever has brass plate that says "Neutrodyne Reciever" with serial number C-8029 and has a tube line-up of 5 226s 1 227 and two 171s power supply has a 280 All tubes are original and work
::Might try the schematic for a Packard Bell 8AC:
::http://www.nostalgiaair.org/PagesByModel/960/M0012960.pdf
:or Allied 8/9 AC:
:http://www.nostalgiaair.org/PagesByModel/659/M0000659.pdf
::Carl T
:Ok thanks carl will try that
:::::Hi all..When I starting collecting radios about 15 years ago I came across a 1927-28 Airline radio (model A-C eight type C Presidential style) It is in a stand up phonograph type of case and has huge lift up top... The Electronics still work...but after a few mnts a transformer begins to get very warm (short somewhere) Anyway ..I can not find a schematic for it or technical data. It has a power supply that everything in it is not sealed in tar..So..I want to replace caps and bring up to spec... All the wires
::::that go to cap block ..well I don't know what the values are...ANY HELP?? Or steer me in the righ direction? THANKS!!!
::::OOOPS also the reciever has brass plate that says "Neutrodyne Reciever" with serial number C-8029 and has a tube line-up of 5 226s 1 227 and two 171s power supply has a 280 All tubes are original and work
:::Might try the schematic for a Packard Bell 8AC:
:::http://www.nostalgiaair.org/PagesByModel/960/M0012960.pdf
::or Allied 8/9 AC:
::http://www.nostalgiaair.org/PagesByModel/659/M0000659.pdf
:::Carl T
