Can't make out schematic - Silvertone 1829
12/28/2008 8:50:56 PMCMcKenna
Hi All,
I have a sears silvertone 1829 console I am currently working on. Here is the link: http://www.nostalgiaair.org/PagesByModel/775/M0016775.pdf
I am having a hard time making out the print on the schematic. What is the chance anyone has a better print. If not, does anyone have better eyes and can tell me the value of the electrolytics?
12/28/2008 9:01:48 PMWarren
:Hi All,
:I have a sears silvertone 1829 console I am currently working on. Here is the link: http://www.nostalgiaair.org/PagesByModel/775/M0016775.pdf
:I am having a hard time making out the print on the schematic. What is the chance anyone has a better print. If not, does anyone have better eyes and can tell me the value of the electrolytics?
It looks to be 14MFD at 500V for the one before the field choke, and 8MFD at 350V for the one after. Sounds to be right in any case.
12/28/2008 9:32:16 PMCMcKenna
Can I use 1 22/450 in place of the 14/500 ?
::Hi All,
::I have a sears silvertone 1829 console I am currently working on. Here is the link: http://www.nostalgiaair.org/PagesByModel/775/M0016775.pdf
::I am having a hard time making out the print on the schematic. What is the chance anyone has a better print. If not, does anyone have better eyes and can tell me the value of the electrolytics?
:It looks to be 14MFD at 500V for the one before the field choke, and 8MFD at 350V for the one after. Sounds to be right in any case.
12/28/2008 10:33:13 PMWarren
:Can I use 1 22/450 in place of the 14/500 ?
:::Hi All,
:::I have a sears silvertone 1829 console I am currently working on. Here is the link: http://www.nostalgiaair.org/PagesByModel/775/M0016775.pdf
:::I am having a hard time making out the print on the schematic. What is the chance anyone has a better print. If not, does anyone have better eyes and can tell me the value of the electrolytics?
::It looks to be 14MFD at 500V for the one before the field choke, and 8MFD at 350V for the one after. Sounds to be right in any case.
Sure, the plate is showing 230 volts, so I think that's just fine. You can use a 10MFD to replace the 8MDF also.
12/28/2008 10:59:43 PMCMcKenna
Thanks for the help Warren. Happy new year!!
Chris
::Can I use 1 22/450 in place of the 14/500 ?
::::Hi All,
::::I have a sears silvertone 1829 console I am currently working on. Here is the link: http://www.nostalgiaair.org/PagesByModel/775/M0016775.pdf
::::I am having a hard time making out the print on the schematic. What is the chance anyone has a better print. If not, does anyone have better eyes and can tell me the value of the electrolytics?
:::It looks to be 14MFD at 500V for the one before the field choke, and 8MFD at 350V for the one after. Sounds to be right in any case.
:Sure, the plate is showing 230 volts, so I think that's just fine. You can use a 10MFD to replace the 8MDF also.
