RCA 25 BP
12/28/2008 7:23:20 PMLee
Hello,
Quick Question, I have a RCA 25BP i would like to replace the power cord on this model but it seems the power cord has a built in 545 ohm resistor, that explains the third wire in the power cord. Could i sub a wire wound power resitor in its place and use a convential power cord?
Thanks for any help
12/28/2008 7:46:42 PMWarren
:Hello,
:Quick Question, I have a RCA 25BP i would like to replace the power cord on this model but it seems the power cord has a built in 545 ohm resistor, that explains the third wire in the power cord. Could i sub a wire wound power resitor in its place and use a convential power cord?
:Thanks for any help
You could use a diode. Have a look here
HTTP://WWW.ANTIQERADIO.COM/COLGLOBE_SEP-OO.HTML
12/28/2008 8:01:01 PMWarren
:Hello,
There is under resources " tips and training " A good article with chart about line cord resistors.
12/28/2008 8:14:24 PMFred R
::Hello,
::Quick Question, I have a RCA 25BP i would like to replace the power cord on this model but it seems the power cord has a built in 545 ohm resistor, that explains the third wire in the power cord. Could i sub a wire wound power resitor in its place and use a convential power cord?
::Thanks for any help
:There is under resources " tips and training " A good article with chart about line cord resistors.
If you want to keep a vintage tube rectifier, you could use a 117Z6-GT which is of the right vintage. Some RCAs came with either a 35Z5-GT with resistor line cord or 117Z6-GT which works directly from the line with no resistor line cord. If you go with a solid state diode, you will need a series dropping resistor. Fred
