First thing comes to mind is a dirty function switch, or if it has a mute switch check that too.
There could be a broken wire or a short or a bad selector switch, as was suggested before.
If you do need a cartridge for it. You can get a new one at Garage-A-Records.com The old Zenith part number is 142-74 .. <> Warren <>
Thanks. It's not a Cobra. I think it is a Model 68683 or is it 6S683? I tried cleaning the switch and no difference so I hooked up a newer style cartridge and got moderate sound so think it is the cartridge.
A model number will be helpful.
Hard to read it but I think it says 6R583 and parts seem to agree with the schematic.
If C4 is open, that will, of course, reduce volume.
Thanks, have tried those components and no luck. still has low volume that doesn't change with the volume control but can't find anything wrong. Must be the cartridge.
:T.
