That resostor has a "negative TC", which means that if the temperature goes up, the resistance goes down. The filaments have a positive temperature coefficient, so that when the set is first turned on, the resistor will allow the filaments to warm up more slowly and keep one from hogging all the Voltage and becoming white hot while the others warm up.
Neal,
What is the chassis number for your radio?
When I looked at the schematic for an H723, that resistor was not in the filament string.
Carl T
It looks like it only goes with the Z2 model.
Oh, the value is 100w nominal. I guess that means room tmperature.
Thats 100 ohms, not 100W, and most likely at room temp as you indicate.
Oops, that from my days at AT&T, where a lower case "w" meant Ohms, and a upper case meant Watts.
:::::::::On a Zenith H723, which is closest to Riders 23-7, model H723Z2: What is resistor R21, in the filament string between the 1st & 2nd IF's. They call it a "special resistor" with no value listed. The only thing I found special about it is that it gets real hot and smokes a lot, and keeps the filaments from lighting up (2.5K ohms, cold). Similar models have a 39 ohm power resistor at that point. What do you suggest? Thanks.....
::::::::That resostor has a "negative TC", which means that if the temperature goes up, the resistance goes down. The filaments have a positive temperature coefficient, so that when the set is first turned on, the resistor will allow the filaments to warm up more slowly and keep one from hogging all the Voltage and becoming white hot while the others warm up.
::::::::Lewis
:::::::Neal,
:::::::What is the chassis number for your radio?
:::::::When I looked at the schematic for an H723, that resistor was not in the filament string.
:::::::Carl T
::::::It looks like it only goes with the Z2 model.
::::::Lewis
:::::Oh, the value is 100w nominal. I guess that means room tmperature.
:::::Lewis
::::Thats 100 ohms, not 100W, and most likely at room temp as you indicate.
:::Oops, that from my days at AT&T, where a lower case "w" meant Ohms, and a upper case meant Watts.
:::Lewis
:::If I bypass that surge resistor completely, and say, change the 36C5 tube to a 50C5,l so that the string adds up to 117 volts, would I be doing anything risky?
