Any help much 'preshiaded
Chris
WebStaff@NostalgiaAir.org
I just pushed the full suite of Triplett 3423 tube tester stuff (manual, 2 variants of calibration proc., & the last supplement issue) to eserviceinfo.com Just search 3423 & Mfr 'Triplett', or browse under "measuring equipment" to Triplett.
NB, if your line voltage indication is wonkey, have a close look at the 305Kohm multiplier, mine was a bit off and unstable. & just for general info, if the Cu oxide meter diode goes duff, a pair of BAT85 Schottky's make a super replacement.
Chris
Send an email to richard@nostalgiaair.org . He is away from his home but checks email.
::I don`t know I can`t see it either,but I am in need of this info,have 3423 and don`t know how to use or calibrate it?If you could email you don`t know how much I`d appreciate it .Thanks Rich
:I just pushed the full suite of Triplett 3423 tube tester stuff (manual, 2 variants of calibration proc., & the last supplement issue) to eserviceinfo.com Just search 3423 & Mfr 'Triplett', or browse under "measuring equipment" to Triplett.
:NB, if your line voltage indication is wonkey, have a close look at the 305Kohm multiplier, mine was a bit off and unstable. & just for general info, if the Cu oxide meter diode goes duff, a pair of BAT85 Schottky's make a super replacement.
:Chris
