:need to locate replacement or find directions to rewind old ones. Can any one help. Thanks Tom
Doug:
I never snip off the center tap, just put some heat shrink and seal the end with pliers. That way, you will have a good transformer if something should happen to to make this radio impossible to repair.
::need to locate replacement or find directions to rewind old ones. Can any one help. Thanks Tom
:Doug:
:I never snip off the center tap, just put some heat shrink and seal the end with pliers. That way, you will have a good transformer if something should happen to to make this radio impossible to repair.
:Lewis
:::need to locate replacement or find directions to rewind old ones. Can any one help. Thanks Tom
