:Seasons Greetings, I need about a 6 inch square piece of veneer to patch top of old Airline console. Yeah, I know Lowes sells it but my closest Lowes store is 35 miles East of me. Heard u could just soak wood in water and it peel off. Hot water? Anything to add to water? Or other methods? Advice greatly appreciated.
If you have a Rockler.com store by you, they sell small pieces of veneer. Check their website, too.
Try also any hardwood store as they usually carry veneer products or have easy access to them.
I used, with good success, a steamer that I had for cleaning metal parts. It is a SHARK brand, carries about 2 cups of water and makes a terrific veneer remover.
As Marv and others say, be patient. The glue will react with the heat and the water for easy removal. I use a wood chisel to get in between the base material and the veneer to "peel" it back. Slowly.......
Make sure the base wood is absolutely dry before applying new veneer. I use contact cement so there is no room for error, bu Elmer's stainable glue works good too. I do not recommend Gorilla glue products as they expand when curing. On curved surfaces, try using bungee cords wrapped around the curves to keep tension/pressure on the veneer during the drying process.
Good luck.
Terry F
:Terry,
:thanks for your suggestions.. I have one of those
:Shark steamers and was going to use it on other parts
:of a radio but did not think of using it for veneer.
:Also the idea of using the bungee cords is another
:one I have not thought of.
: And Jim...a cheap iron can be had a thrift store if
:your wife is not too swift on you using it for gluey
:jobs on radios :O)
:Bob E
NO LUCK SO FAR, that is removing some veneer. And Bob, we did have an extra iron to use. Its a steam iron so will put water in it and try again. Called local lumber co. and they do not stock veneer
Cloth and paper backed veneer come in rolls. Architectural veneer that is. Too thick for radio restoration use.
Syl
It is vEneer nor vAneer.
English being my second language, I cringe evertytime I read your replies. I have been a teacher in high school for a few years and I seriously doubt you are a member of the profession.
Syl
Syl
Try www.constantines.com
All:
I am lucky enough to have a Woodcraft shop here in Louisville. They have an amazing supply of veneers, toning laquers etc. Try them online and send for their catalog. I bought a large roll of cherry veneer for radio work and found it has great grain patterns and is nuetral enough in color that it can be stained most any color quit well. It is paper backed and is easy to work with.
Jon.
