Chassis cleaning
12/4/2008 5:53:47 PMDavid D.
What’s a good economical way to clean radio chassis?
12/4/2008 8:51:34 PMTerry F
David,
Check this thread for ideas/suggestions.
Good luck.
Terry F
http://www.nostalgiaair.org/forums/Messages/028/M0043028.htm
12/5/2008 2:03:49 AMG. Berg
Hi ...The best method I have used is a tooth brush or 3M Scotch Brite brillo plastic pads and plain-old rubbing alcohol. I use $.99 alcohol because unlike water it evaporates fast and helps to cut grease. Also the cheap small wire brushes at dollar stores work good. Some people on here throw the whole chasie in the dishwasher..a good idea and works great..BUT if you want to pleserve paper labels and cloth covered wire...not such a good idea...
:David,
:Check this thread for ideas/suggestions.
:Good luck.
:Terry F
:http://www.nostalgiaair.org/forums/Messages/028/M0043028.htm
