Sometimes a wafer switch will arc over and carbonize. Carbon causes a resistive path. You might be able to did out the burnt area?
:I have this old National NC98 and when the voltage hits the band switch it was shorting out to ground. Now it measures 88 ohms to ground all the time so pulls down the B+. I have isolated the short to this one wafer on the band switch--measures 88 ohms to ground. Cannot see anything wrong with the switch but is 88 ohms to ground. I have never seen this happen to a band switch and how in the world do you repair it. Looks like it would be impossible to get out as there are three wafers on this one shaft and tons of wires.
:John
: Sometimes a wafer switch will arc over and carbonize. Carbon causes a resistive path. You might be able to did out the burnt area?
::I have this old National NC98 and when the voltage hits the band switch it was shorting out to ground. Now it measures 88 ohms to ground all the time so pulls down the B+. I have isolated the short to this one wafer on the band switch--measures 88 ohms to ground. Cannot see anything wrong with the switch but is 88 ohms to ground. I have never seen this happen to a band switch and how in the world do you repair it. Looks like it would be impossible to get out as there are three wafers on this one shaft and tons of wires.
