Gluing Grid Caps
11/25/2008 2:19:42 PMMike M.
I read in a previous post about gluing grid caps on tubes.
How does this effect the operation of the tube without an internal vacuum?
Mike M.
11/25/2008 5:05:58 PMknobsrmisn
:I read in a previous post about gluing grid caps on tubes.
:How does this effect the operation of the tube without an internal vacuum?
:Mike M.
11/25/2008 5:11:13 PMknobsrmisn
::I read in a previous post about gluing grid caps on tubes.
::How does this effect the operation of the tube without an internal vacuum?
::Mike M.
A loose grid cap does not cause a loss of vacumm, nor does a loose base unless the glass is cracked or broken in which case the tube is done for.
