Fuse for Zenith Royal 7000?
11/23/2008 11:26:33 PMTimothy S.
All of a sudden, my Zenith Royal 7000 shortwave radio does not have power. I checked the voltage at the end of the wire (to the unit), good power, but nothing to the radio. I looked inside, made certain the switch was to '115 v', and checked again, no go. Any ideas guys? Thanks, Timothy S.
11/24/2008 10:32:56 AMWarren
:All of a sudden, my Zenith Royal 7000 shortwave radio does not have power. I checked the voltage at the end of the wire (to the unit), good power, but nothing to the radio. I looked inside, made certain the switch was to '115 v', and checked again, no go. Any ideas guys? Thanks, Timothy S.
I don't think there is a fuse as such. The transformer has internal protection. Check the primary of the transformer with an ohm meter, then the secondary. Don't overlook the simple such as a bad on off switch.
11/24/2008 11:36:03 AMTimothy S.
Thank you very much! I will go home tonight and go further into the radio. Thanks for the reply. Timothy S.
11/24/2008 3:42:22 PMSteve - W9DX
:Thank you very much! I will go home tonight and go further into the radio. Thanks for the reply. Timothy S.
Have you tried it with batteries? At least that would tell you if it's just the AC power suppy or not.
Steve
11/24/2008 8:46:41 PMTimothy S. Miller
No, but will try that! Thanks...didn't think of that..Thank you!
Timothy S.
www.ukraineyouthcamps.com
