:Dale, could not get your email adr. by clicking on ur name, so must communicate with u here. I have a Philips-Sagitta 363A which has some of those foreign tubes. Mine made in Germany, has German words on cover and will also operate on the European voltage of 220 volts. Yours or mine not listed here under these names. Mine does not have the ef 82, mine is ef 89 and othes are ech 81, eab 80, and a ez 80 which I think is rectifier tube. Mine has a EM 80 for tuning eye tube. E mail me for more info, Jim
:Jim, Thanks for the follow-up. One of my unknown tubes is _ch81, so based on your tube set I'm going to assume it is a ECH81. My other unknown tube ends in "80", but I don't know the preceeding letters. The Grundig I have was made for the USA market -- operates on 110 volts.
::Dale, could not get your email adr. by clicking on ur name, so must communicate with u here. I have a Philips-Sagitta 363A which has some of those foreign tubes. Mine made in Germany, has German words on cover and will also operate on the European voltage of 220 volts. Yours or mine not listed here under these names. Mine does not have the ef 82, mine is ef 89 and othes are ech 81, eab 80, and a ez 80 which I think is rectifier tube. Mine has a EM 80 for tuning eye tube. E mail me for more info, Jim
:Dale,
:Seems that the EF82 tube was not common in radios.
:Could it possibly be EF89 like Jim has in his radio?
:And like Jim mentioned, it probably has an EZ80 rectifier, and the tuning indicator is probably an EM85.
:Carl T
::Jim, Thanks for the follow-up. One of my unknown tubes is _ch81, so based on your tube set I'm going to assume it is a ECH81. My other unknown tube ends in "80", but I don't know the preceeding letters. The Grundig I have was made for the USA market -- operates on 110 volts.
:::Dale, could not get your email adr. by clicking on ur name, so must communicate with u here. I have a Philips-Sagitta 363A which has some of those foreign tubes. Mine made in Germany, has German words on cover and will also operate on the European voltage of 220 volts. Yours or mine not listed here under these names. Mine does not have the ef 82, mine is ef 89 and othes are ech 81, eab 80, and a ez 80 which I think is rectifier tube. Mine has a EM 80 for tuning eye tube. E mail me for more info, Jim
http://www.mbzponton.org/n2awa/grundig2066px.html
Carl T
:Carl & Jim,
:I am sure of 3 of the 6 tubes: EL84, ECC85, & EM84 (tuning tube). The other (uncertain) 3 are EF8? (probably EF89), ?CH81 (probably ECH81) & ????80 (this one might be EABC80). Do either of you know of a source for Grundig schematics? THANKS! Dale
::Dale,
::Seems that the EF82 tube was not common in radios.
::Could it possibly be EF89 like Jim has in his radio?
::And like Jim mentioned, it probably has an EZ80 rectifier, and the tuning indicator is probably an EM85.
::Carl T
:::Jim, Thanks for the follow-up. One of my unknown tubes is _ch81, so based on your tube set I'm going to assume it is a ECH81. My other unknown tube ends in "80", but I don't know the preceeding letters. The Grundig I have was made for the USA market -- operates on 110 volts.
::::Dale, could not get your email adr. by clicking on ur name, so must communicate with u here. I have a Philips-Sagitta 363A which has some of those foreign tubes. Mine made in Germany, has German words on cover and will also operate on the European voltage of 220 volts. Yours or mine not listed here under these names. Mine does not have the ef 82, mine is ef 89 and othes are ech 81, eab 80, and a ez 80 which I think is rectifier tube. Mine has a EM 80 for tuning eye tube. E mail me for more info, Jim
:Dale,
:There is a link to a 2066PX schematic on this page that might match your radio:
:http://www.mbzponton.org/n2awa/grundig2066px.html
:Carl T
::Carl & Jim,
::I am sure of 3 of the 6 tubes: EL84, ECC85, & EM84 (tuning tube). The other (uncertain) 3 are EF8? (probably EF89), ?CH81 (probably ECH81) & ????80 (this one might be EABC80). Do either of you know of a source for Grundig schematics? THANKS! Dale
:::Dale,
:::Seems that the EF82 tube was not common in radios.
:::Could it possibly be EF89 like Jim has in his radio?
:::And like Jim mentioned, it probably has an EZ80 rectifier, and the tuning indicator is probably an EM85.
:::Carl T
::::Jim, Thanks for the follow-up. One of my unknown tubes is _ch81, so based on your tube set I'm going to assume it is a ECH81. My other unknown tube ends in "80", but I don't know the preceeding letters. The Grundig I have was made for the USA market -- operates on 110 volts.
:::::Dale, could not get your email adr. by clicking on ur name, so must communicate with u here. I have a Philips-Sagitta 363A which has some of those foreign tubes. Mine made in Germany, has German words on cover and will also operate on the European voltage of 220 volts. Yours or mine not listed here under these names. Mine does not have the ef 82, mine is ef 89 and othes are ech 81, eab 80, and a ez 80 which I think is rectifier tube. Mine has a EM 80 for tuning eye tube. E mail me for more info, Jim
