Try Acetone or nail polish remover on the wire. It will melt off the enamel coating. Solder, then glue in place.
:::WOW!!! Frustration. I found a broken lead inside the IF Interstage Transformer on my Silvertone 1828. It's no longer long enough to make a solid re-connect so I am trying to solder another piece of wire to it. This is that really small coil wire. I can wrap another piece to it and make the radio work but any movement knocks it out. I can't get the wires to accept solder. Tried a dab of flux, make sure they're clean etc. How does one repair something like this? Thanks!
:::One "Loosing hair by the minute" Johnny
::Try Acetone or nail polish remover on the wire. It will melt off the enamel coating. Solder, then glue in place.
::Okay that's worth a try. What if I wanted to replace the whole transformer? I'm not sure but I believe this would be the 1st IF transformer. Can it be replaced with another 1st IF transformer from another radio? I've got another one that is physically the same and even fits inside the existing can. How are these things rated? 455KC, 456KC etc.? Thanks!
:Johnny
