With the vibrator out, you can apply 6 volts to it. If it does the buzz thing, it's working. Sometimes the contact points in it weld shut. You can still get new 6 volt vibrators.
:I'm looking for some help in restoring a vibrator radio. From what I understand, I must apply full 6 volts to the radio. Are there checks I can perform first to test the vivrator?
:I've seen various posts regarding the use of a computer power supply. Would 5 volts sufficiently operate a vibrator radio?
::I'm looking for some help in restoring a vibrator radio. From what I understand, I must apply full 6 volts to the radio. Are there checks I can perform first to test the vivrator?
